Interesting point I think, would you mind to continue the discussion here?
Again, @GG_jr can ask whatever he wants, ready to convince the community to support his proposal, discussing and defending such improvement.
People MUST compare NethServer to other distributions because we need to improve the product learning from others. If others have already a feature we should ask ourselves why and discuss if itâs worth to develop it or not.
Asking, proposing and discussing is enough for me.
Check also:
Provide your voice in NethServer development and roadmap
Please, stop these kind of sentences once and for all
they donât fit our culture and donât help people, they scares them indeed. Thank you, hope you understand
well, looks like both of you just misunderstood me or I wasnât able to explain meâŠ
asking for feature is not a bad idea, even if NFR should be in some way catalogued, just to see WHAT people ask and discuss the opportunity to develop them or not⊠is there such a catalogue? where it is?
The real fact here is that there are way too many âhei guys, add this, that, $whateverâ e really few âoh, guys, how can I add this feature? Iâm really interested, I need itâ
moreover, such a requests are seldom just âdo itââŠ
when you talk about âour cultureâ, who are you referring to? the community?
anyway, I NEVER told anyone (if I did it I apologized and Iâm ready to do it right now again) here or elsewhere to STOP talking/writing.
How many is âtoo manyâ?
Seriously, Iâm a man of science, where do you set âyour barâ? And why?
From the screenshot you provided I see both Zentyal and Endian have only one parameter. I think one is enough; the other can be calculated.
Of course, you didnât do it directly but people stop doing it anyway because they donât feel comfortable to continue the discussion after your post.
Indeed.
Please correct me if Iâm wrong: The total size of an email is given by the âsize of the bodyâ plus the âsize of the attachmentâ. Of course i saw many times pictures in the body of the emails (not as attachment), but the size of the body, usually is smaller than the size of the attachment.
So, I think the size of the attachment is more important, and IMO, this parameter should be adjustable.
I also used Axigen as email server. And there, this parameter is adjustable.
Iâm sure, together, we will find the proper solution!
No other solutions, that fun you are no more in the user-case of an email server, but clearly here in a file server.
The size of the attachment multiplied for 1.33.
We can have a single value and do the math.
I reviewed the Endian documentation about the email size.
They refer only at âmaximum email content sizeâ (I think the whole email: body and attachment):
"Choose maximal email contentsize:
The maximum size allowed for a single e-mail message. Several predefined values can be selected from the drop-down menu*. Choosing the custom email contentsize option reveals the next option.
Custom maximum email contentsize (in KB):
The maximum size in mega bytes of the e-mail that will be accepted by the SMTP server."
*Drop-down menu: custom maximum email content size; 5 MB; 10 MB; 15 MB; 20 MB; 25MB; 30 MB; 35 MB; 40 MB; unlimited email contentsize.
So the same NethServer property, right?
Yes, if we put â=â between âThe Queue message max sizeâ and âMaximum email contentsizeâ.
Also by definitions:
NethServer: The Queue message max size slider sets the maximum size of messages traversing the system
Endian: The maximum size in mega bytes of the e-mail that will be accepted by the SMTP server
In NS itâs about mesages and in Endian itâs about a single e-mail message. And the Queue is a âplaceâ for all messages.
Iâm not sure if itâs about the same thing.
AFAIK they are the same thing,
our Postfix template sets the following parameter
http://www.postfix.org/postconf.5.html#message_size_limit
We can easily convert that value to a max upload size for Roundcube configuration. IIRC sogo has a similar setting. If the weight of all attachments exceedes the limit a SMTP error is returned to the application.
message_size_limit
(default: 10240000)
The maximal size in bytes of a message, including envelope information.
Note: be careful when making changes. Excessively small values
will result in the loss of non-delivery notifications, when a bounce
message size exceeds the local or remote MTAâs message size limit.
queue_directory
(default: see âpostconf -dâ output)
The location of the Postfix top-level queue directory. This is the
root directory of Postfix daemon processes that run chrooted.
queue_file_attribute_count_limit
(default: 100)
The maximal number of (name=value) attributes that may be stored
in a Postfix queue file. The limit is enforced by the cleanup(8)
server.
This feature is available in Postfix 2.0 and later.
queue_minfree
(default: 0)
The minimal amount of free space in bytes in the queue file system
that is needed to receive mail. This is currently used by the
Postfix SMTP server to decide if it will accept any mail at all.
By default, the Postfix SMTP server rejects MAIL FROM commands when
the amount of free space is less than 1.5*$message_size_limit
(Postfix version 2.1 and later).
To specify a higher minimum free space limit, specify a queue_minfree
value that is at least 1.5*$message_size_limit.
With Postfix versions 2.0 and earlier, a queue_minfree value of
zero means there is no minimum required amount of free space.
queue_run_delay
(default: 300s)
The time between deferred queue scans by the queue manager;
prior to Postfix 2.4 the default value was 1000s.
This parameter should be set less than or equal to
$minimal_backoff_time. See also $maximal_backoff_time.
Time units: s (seconds), m (minutes), h (hours), d (days), w (weeks).
The default time unit is s (seconds).
queue_service_name
(default: qmgr)
The name of the qmgr(8) service. This service manages the Postfix
queue and schedules delivery requests.
From all of above, I understand that if an email have 20 MB (message size), it can be delivered by the Postfix SMTP only if the Queue (directory) have more than 1.5*20=30 MB. Am I wrong?
You are right.
The cursor from GUI set the message size limit, not the Queue message max size.
So, you can set the maximum size limit of a mail message from GUI.
Itâs a labeling error which generate misunderstanding. Can you fix this?
PS
I think that the cursor for âQueue message lifetimeâ should be in âQueue managementâ section.
We could change it to âMessage max sizeââŠ
Iâm not an English expert, letâs listen to othersâ ideas
