Loaded plugins: changelog, fastestmirror, nethserver_events, presto
- nethserver-base: nethserver.antani.co
- nethserver-updates: nethserver.antani.co
Listing 1 changelog
==================== Updated Packages ====================
spamassassin-3.4.1-7.el6.x86_64 nethserver-updates
- Tue Jul 14 05:00:00 2015 Kevin Fenzi kevin@scrye.com 3.4.1-7
- Fix typo with amavis restart in sa-update cron for el systems
owncloud-7.0.10-1.1.noarch nethserver-updates
- Fri Sep 11 05:00:00 2015 jw@owncloud.com
- Update to version 7.0.10
nethserver-owncloud-1.1.6-1.ns6.noarch nethserver-updates
- Tue Sep 22 05:00:00 2015 Giacomo Sanchietti giacomo.sanchietti@nethesis.it - 1.1.6-1
- Update to owncloud 7.0.10 - Enhancement #3261 [NethServer]
nethserver-release-6.7-0.4.ns6.noarch nethserver-updates
- Thu Oct 15 05:00:00 2015 Giacomo Sanchietti giacomo.sanchietti@nethesis.it - 6.7-0.4-1
- Requires nethserver-firewall-base
changelog stats. 5 pkgs, 4 source pkgs, 4 changelogs
Oct 19 14:19:25 server7b pkgaction[1887]: install:
Oct 19 14:22:03 server7b pkgaction[1887]: [YumDownloadError] [u’Errors were encountered while downloading packages.’, u’libmnl-1.0.2-3.el6.x86_64: failure: Packages/libmnl-1.0.2-3.el6.x86_64.rpm from centos-base: [Errno 256] No more mirrors to try.’, u’bc-1.06.95-1.el6.x86_64: failure: Packages/bc-1.06.95-1.el6.x86_64.rpm from centos-base: [Errno 256] No more mirrors to try.’, u’ipset-6.11-3.el6.x86_64: failure: Packages/ipset-6.11-3.el6.x86_64.rpm from centos-base: [Errno 256] No more mirrors to try.’, u’ppp-2.4.5-5.el6.x86_64: failure: Packages/ppp-2.4.5-5.el6.x86_64.rpm from centos-base: [Errno 256] No more mirrors to try.’]
