I don’t see a way to set the number of messages per page?
Also, the default timezone is set to Europe/Rome, does not set to NS timezone. There should also be a way to set the default Language and Date Format for each user, as well as the timezone.
hmm, no not solved - the grey-Theme is not working…for all, me?? - and I’m normally use grey, because for me everything is grey
OK, tested all themes.
For me, Classic, Crisp, Neptune works (Web Top, Outlook, Mozilla) and Grey don’t work (Web Top, Outlook, Mozilla).
In WebTop5 it was introduced infinite scrolling for the email list and for that reason there is no longer the number of mails per page to be set
It sounds like a good idea to take the timezone from the NS
Also a setting for all users by Language and Date Format to be inserted between the global properties it seems useful, what do you think @gabriele_bulfon ?
I confirm that the theme Grey has some problems
I think @gabriele_bulfon he already aware and will be removed in a future release.
Can’t see my second user(I’ve only 2 at the moment).
I think, I should see my second user, but I can’t.
I’m using samba AD and deinstalled sogo before installing webtop 5.
I just want to invite my second user to a new event - I’m so lonely
Hi @maddin ,
it is necessary that the second user has made at least the first login in Webtop to view available.
Alternatively you can access the admin console -> Users -> double click on the user and then save and close to enable
In the current version of nethserver-webtop5 in nethserver-testing:
nethserver-webtop5-0.0.1-1.24.g8dd5f04.ns7.noarch
were inserted presetting from “Authorizations” in the Users group.
Among these it was also included ActiveSync enabled:
Hi Luca,
Thank you for your answer.
I thought that is possible, so I have tried and it works:
WebTop 5 needs testing
Since this thread is too big to handle, I just split some posts in new topics.
