Yes, WebTop 4. But beside it, there is also Tomcat and other dependencies. Maybe some of them, as version, are not compatible with the version which came with WebTop 5.
But, I can roll back this exact same machine to before WebTop 4 was installed and the WebTop5 works.
If you need the emails, you can use Thunderbird or other Desktop Email client to download them by IMAP and after rollback and install WebTop 5, you can have them back.
Yes, I realize that, but I have everything else configured on my server, network shares, NextDrive, email aliases. It is just a test server, but I have setup a lot on it, and I would not want to just start over.
Yes, I want to try it on a live system, MY live system, with all my configuration setup for other apps, my LE cert etc. but I cannot uninstall WT4 and re-install WT5. Surely someone else has done this? No?
Publish always up to date source code
Basic developer and user documentation
Translations opened to external contributors using a public tool
Better mail client with improved Sieve filters, folder subscriptions Migration path from WebTop 4 to WebTop 5
Yes, but I run on a VM, I took a snapshot before trying the upgrade, and just rolled back. I will install a 2nd test VM and check out WT5, itâll just be harder to test with noone using it.
got the same error (but logs might tie it to a different source cause, logs were showing password authentication error and non-existent sonicle role). What worked in my case was to delete webtop databases and sonicle user from postgresql, and reinstalling webtop5. Donât know if devs will recommend against it, as Iâm removing more things than really needed.
WARNING - Donât try this in production.
This is not an upgrade path, it ditches most of webtop config/dataâŚ(make backup/snapshot beforehand)
CASE 1 - With webtop4 installed, before installing webtop5:
Regarding âSelect âCompleteâ inside the âSynchronizationâ fieldâ
Inside the âSyncronizationâ field will find only âOffâ, âRead-Onlyâ, âFullâ.
You must select âFullâ. @giacomo :
Can you modify this documentation according to this tags?
Regarding âActiveSync must be enabled for each usersâ
ActiveSync cannot be set for the entire Users group (Domains -> NethServer -> Groups -> Users)? At least in the final version?
