cc: @gabriele_bulfon
Thank you for your help!
Unfortunately I have the same error even after I have rebooted the server.
In my firefox on a win7 machine everything seems to be o.k.
Did you clear your browser-chache? Or is it maybe win10 related?
EDIT: Tested also gray and crisp theme. No problems on my side with calendar.
Before adding the issues, confirm me this:
My steps for installing and update WT 5 with Open LDAP:
Welcome, WebTop 5! - #3 by robb
with this command:
yum --enablerepo=nethserver-testing install nethserver-directory nethserver-webtop5
with this command:
yum --enablerepo=nethserver-testing install nethserver-webtop5
with this command:
yum --enablerepo=nethserver-testing update nethserver-webtop5 webtop5*
In my webtop the date-format in calendar isnât correct.
calendar format is mm/dd/yy but in settings I set dd/mm/yyyy.
seems that changing of date-format in settings have no affect to the calendar date-format. changing startdax of week works.
I canât reproduce it, maybe a problem between different test packages?
Could you wipe the whole webtop5 installation?
yum remove nethserver-webtop5 webtop5-core webtop5-libs webtop5-zpush
rm -rf /var/lib/tomcats/webtop
I think yes. Because of this I have shown âmy stepsâ.
Give me 5 minutes please.
I will report back.
OK!
Everythingâs back to normal!
Thank you!
Back to tests!
Thanks Gabriel for your great support!
How can I install if I have Webtop4 installed already?
I uninstalled using the web interface, then on install it errored as webtop4-core, webtop4-lib, webtop4-zpush still installed. I uninstalled manually using yum, and now I get the following error on /webtop;
HTTP Status 500 - java.lang.NullPointerException
sry, was away.
And now first - I like webtop - easy, simple just what I needâŚbut:D
At the moment I have a problem to download Language-pack, donât know why something with DNS? I will give it a try - promised!
OK, I like the cloud, but when I created a link, there is no way to get the link again. So, if I have a file in cloud which I want to send more than one person I have to find the first Email with the link in it.
yum remove nethserver-webtop4 webtop4-core webtop4-libs webtop4-zpush
( rm -rf /var/lib/tomcats/webtop )
I had already tried that, but I did try again, and same problem.
If it has anything to do with it, I have the following packages installed;
Backup, Email, File Server, MariaDB (MySQL) server, Nextcloud, POP3 connector, and have an LE cert.
I am running on a VM, so I was able to roll it back to a fresh updated install, and it was able to install WebTop5 without issue, but current system cannot. But, then all my email is gone.
type Exception report
message java.lang.NullPointerException
description The server encountered an internal error that prevented it from fulfilling this request.
exception
âŚ
I think is a major incompatibility between WT 4 and WT 5 (maybe also with Tomcat).
Anyway, the emails should be there even if WebTop canât start in browser. The emails are not kept by WebTop. After I have reinstalled WebTop 5 (please see my issue from above), all my emails was there.
Of course the emails are not in the new installation, after rollback.
But, if WT4 is completely uninstalled, should it not work.
And, that is what I meant, I canât roll back as emails wonât be there, just testing to see if WT5 would install.
Iâm stuck, really want to try WT5 on live system.
Yes, WebTop 4. But beside it, there is also Tomcat and other dependencies. Maybe some of them, as version, are not compatible with the version which came with WebTop 5.
I think basically WebTop 5 can be used on a live system.
Is not finished but can send and receive emails (at least) without issues.
If you need the emails, you can use Thunderbird or other Desktop Email client to download them by IMAP and after rollback and install WebTop 5, you can have them back.
Only if just an issue with the WebTop.
As is written here:
https://nethserver.github.io/webtop5/#roadmap
all basic functions works.
You can read more from the beginning:
