You are welcome!
After this update, an error occurred, even after reboot:
Maybe you have a session retrying in your browser, if you didnât close it before accessing the new updated system.
Close every browser window before accessing, or access ââŚ/webtop/logoutâ to destroy the session.
Hi Gabriele,
I have tried with other 2 browsers (MS Edge, IE 11) and I have the same problem.
Here is what I obtained after ââŚ/webtop/logoutâ:
Updated an existing webtop 5 on a NS7final-VM with OpenLDAP without issue.
One thing I found:
This is not translated yet to english.
Did you try restarting tomcat? (service tomcat@webtop stop/start)
Those notifications shouldnât be visible yet, theyâre still being implemented.
Are you sure you updated to latest release?
Also, can you try restarting tomcat?
I have restarted the server. The same situation.
Everything worked fine till yum --enablerepo=nethserver-testing update nethserver-webtop5 webtop5*
can you show your last catalina.out errors?
If you tell me the command âŚ
PS:
I can send and receive emails.
Java applications are hard to debug (at least for me).
Yesterday I added some notes here:
Latest version. yum says no packages marked for update.
Restarted the hole machine. The Bell-icon is still there.
BTW: my calendar-layout is normal. Chrome on Win7.
very very very strange, it shouldnât be there⌠@giacomo correct me if Iâm wrong: latest version shouldnât have the bell icon.
installed versions from nethserver-testing:
webtop5 version: 1-1.17.g5d33838
nethserver-webtop5 version: 1-1.24.g8dd5f04
Donât worry anymore. After I cleared the browserchache the bell-icon is gone.
No, the rpm takes care to automatically configure WebTop in all scenarios
OK!
Another thing.
Here:
https://github.com/NethServer/nethserver-webtop5#tomcat-instance
you say that âsome special Java optionsâ are in /etc/sysconfig/tomcat/tomcat@webtop, but my path is /etc/sysconfig/tomcat@webtop.
Could be a problem?
No, itâs an error in the doc. I just updated it
I just want to recap reported issues:
calendar doesnât look right in Firefox (@maddin)
the button to show password fields is not centered (@maddin)
download of uploaded files doesnât work (@maddin, I can reproduce it but I have only a 500 response status code without any further information inside logs)
the web application is not accessible after update (@GG_jr)
Gabriele suggested this fix:
systemctl stop tomcat@webtop
rm -rf /var/lib/tomcats/webtop/work/Catalina/localhost/*
systemctl start tomcat@webtop
We are investigating, in the mean while, @gabriele_bulfon or @matteo.albinola could you link here a reference to the opened issues?
