done. set as verified great work @dnutan
tnx!
Thanks to @dnutan and @dz00te the package has been just released!
In nethserver-updates:
nethserver-backup-data-1.3.0-1.ns7.noarch.rpm
Hi @davidep, I think there is a side effect into adding this package. I just ran a routine update and discovered that there was a dependency problem
Error: Package: nethserver-backup-data-1.3.0-1.ns7.noarch (nethserver-updates)
Requires: davfs2
Looks like davfs2 isnāt available in standard CentOS7.
Thanks for looking into this.
Matthieu
davfs2 package is in epel repository.
Sure @dnutan, but as far as I know Epel isnāt enabled by default so every user who hasnāt enabled it will get this message. Moreover, epel can give other problems. I disabled it recently because nextcloud got updated to a nethserver unsupported version.
AFAIK on Nethserver 7 itās enabled by default.
Okay, didnāt know that. I disabled it because of this parasitic nextcloud update that came through epel. I hope itās solved now.
I enabled it back : everything ok.
