It may be a bug.
In 7.2 we created web filter groups as “userlist”, exploding all group members. This had the drawback that lists had to be exploded from time to time.
In 7.3 we rely on the system group so that group modifications take effect immediately.
It seems that in your system group members can’t be discovered.
Please check /etc/ufdbguard/ufdbGuard.conf for the group definition.
Then check user membership. Using the above info you provided: id ljperez
It should be a member of the right group.
src src_somegorupprofile {
unix group "somegroup@mydomain.com"
That looks OK
[root@gate ~]# id ljperez
uid=1010(ljperez@mydomain.com) gid=1001 groups=1001,1004(somegroup@mydomain.com)
That also looks fine.
I tried recreating everything: profile, filter, group, user. With different names, and the problem is always with the profiles that has a group as “Who”.
To be sure to download the updated package you can use: yum install http://packages.nethserver.org/nethserver/7.3.1611/testing/x86_64/Packages/nethserver-squidguard-1.6.1-1.2.g2e08f4a.ns7.noarch.rpm
