NethServer Version: NethServer release 7.3.1611 (Final)
Module: Squid Cache: Version 3.5.20 / ufdbgclient: 1.32.4
Web content filtering is not working well.
If I disable it, that all right, no filtering
If I enable it, I first have to do a ‘service squid stop’, then add some domains to blacklist, then click SUBMIT
If I just go on edit some domains then SUBMIT, nothing happens
At this point I deleted all custom domains from the ‘global blacklist’ and I still get blocked by ufdb on the ones I entered previously
If I restart ether squid or ufdb: same thing.
I checked /var/squidGuard/blacklists/custom/blacklist/domains => empty as expected
So I tried to rebuild db files running
ufdbConvertDB /var/squidGuard/blacklists/custom/
before restarting the whole thing with no more success
I suspect there is something wrong the way ufdb manages domain db files
