After installing Nethserver and succesfull connecting W10Pro client to AD, all shares can be mapped, only home directory is not accesible. Windows is claiming that authorisation is incorrect.
So far I’ve found no clues in the forum or internet.
yes, nethserver gets a bit confusing here
are you mapping the homeshare from a script, or from a groupolicy?
currently, i have a mapping.cmd running from inside the user’s startup folder, this seems to map all the shares correctly under network places you see a username@domainname folder, which is equal to the username folder, i can map both folders, and they show the same content
I tried mapping from windows explorer. just to test
Is there some example for a script and where do I have to store it, where is the users startup folder?
I guess I put the script within a shell in the right diretory on the server since I don’t see any tools within de web interface. Or should it be put on the windows 10 client?
So I made a file in the windows start directory and all mapping works just fine except the mapping to the home directory, the connection is still refused.
Contents of the file:
net use all /delete
net use H: /home
net use I: \\yz2nsrv\fotos /persistent:yes
net use J: \\yz2nsrv\yzermuziek /persistent:yes
net use K: \\yz2nsrv\downloaddata /persistent:yes
net use L: \\yz2nsrv\backup /persistent:yes
net use M: \\yz2nsrv\oc-data /persistent:yes
when I use for home directory the following command I see a mapping H: but this one is also not available
net use H: \\yz2nsrv\guus
My computer has joined the domain so why does the home mapping not function? Where doe I have to look to solve this?
your test gave me the clou.
Created a new account, log messages looked good and mapping to home directory possible.
My guess is that since I created the home directories with rsync data transfer from old server that after changing the GID/UID this wasn’t sufficient and probably causing the connection error.
The UID as well as the GID are wrong, because they are the unix parameters of the old server, not the samba parameters.
How easy the solution can be.
Thanks for all support helping me to the solution.
