UPS APC Battery backup bx1400ui
NethServer release 7.3.1611
I have this ups with connection usb,
i often use this UPS with APCUPSD
but i can’t find the way to use it in NETHSERVER.
i try all apc in section UPS but probably i made errors…
has anyone used this ups?
thanks for support
Did you verified that NUT supports your device?
For your UPS the driver should be usbhid-ups.
I had a different APC model but worked using the same driver.
pike thanks for reply, but a lot of compatible models are not in HCL…(BX1400 is not in the list)
i ask only for know if someone have been used this UPS model…
thanks dnutan , i’ll retry but maybe i have already tried without success…
so it’s my first nethserver and now for test i use an UPS of atlantis land…
without problems…
i update 3d as soon as possible
thanks in advance
Carlo
We using Legrand/Bticino Daker DK1000 with blazer_usb driver connected via usb
[quote=“Carlo, post:4, topic:7111”]pike thanks for reply, but a lot of compatible models are not in HCL…(BX1400 is not in the list)[/quote]Have you verified if it’s compatibile or not? Sometimes it’s not listed because someone does not update the HCL…
hi all! sorry for late but are very hard days…
i try APC BX1400 without success … i write to nut dev team , but i havent response
now i still using my ATLANTIS LAND and for now all seems good
