Hmm… not sure what you mean. I was referring to the Quota column in the Users page in NextCloud. The quota can be changed per user from there, and also the default quota can be changed from the “gear” button in the lower-left corner of the same view.
Thanks a lot for your tests @lucian & @medworthy
Now, it could be useful if you want to update the issue https://github.com/NethServer/dev/issues/5155 with your tests description and you can also set the label to “verified”.
Then we can proceed with the final release
just click on on Labels,
then deselect Testing and click on verified
I don’t have access to the gear icon (and therefore no option to to change the label).
Thanks
Just updated the label to “verified”
Thanks to all of you! @medworthy @davidep @alep @dz00te @lucian NextCloud 10.0.1 is going to be released soon!
