UI Reverse proxy not worked
NethServer Version: 7.3.1611
Module: Reverse proxy
UI Reverse proxy not worked. I had to do manually as it is written here - http://docs.nethserver.org/en/latest/proxy_pass.html#manual-configuration. Why make the possibility of control via web interface if it doesn’t work?
Can you describe what is wrong…it does’t work cannot help us to debug your problem :slight_smile:
