Transparent Proxy and www.ryanair.com
Good Monday!
have you problems with www.ryanair.com?
I have trasparent proxy SSL with Block HTTP and HTTPS ports
I accidentally discovered this morning after updating this new feature, congratulations
But it probably does not work since I blocked direct traffic
In tail -f /var/log/ufdbguard/ufdbguardd.log |grep 192.168.1.7
i found only blocked direct ip, nothing else
Hi Enzo,
what do you see at access.log of squid?
1499073642.061  40050 192.168.1.7 TAG_NONE/200 0 CONNECT 37.18.148.206:443 - HIER_NONE/- -
1499073642.061  39975 192.168.1.7 TCP_TUNNEL/200 3239 CONNECT www.ryanair.com:443 - ORIGINAL_DST/37.18.148.206 -
1499073642.167     99 192.168.1.7 TCP_MISS/301 329 GET http://www.ryanair.com/ - ORIGINAL_DST/37.18.148.206 -
I think access.log looks good.
I tried with non transparent proxy and I get a certificate error (wrong name). The certificate is for urlfilterdb
After ignoring the certificate message I can open the site.
Now ryanair.com work with transparent proxy
