Transmission-daemon won't start
I also had to do it.
After the installation has had the right to Downloads catalog (somehow had the right root):
ls -l
total 20
drwxr-xr-x 2 transmission transmission 4096 Feb  4 14:23 blocklists
drwxrwxr-x 3 root         root         4096 Jan 30 12:33 Downloads
drwxr-xr-x 2 transmission transmission 4096 Feb  4 14:28 resume
-rw------- 1 transmission transmission 2245 Feb  4 14:24 settings.json
drwxr-xr-x 2 transmission transmission 4096 Feb  4 14:28 torrents
Sorry i don’t understand your issue, can you reformulate it again
After installing the transmission module, the service does not run and it turned out that packages transmission and transmission-daemon have not been established.
# rpm -qa | grep transmission
nethserver-transmission-1.1.1-1.ns7.sdl.noarch
transmission-common-2.92-1.el7.geekery.x86_64
transmission-cli-2.92-1.el7.geekery.x86_64
And only in this thread I found that to be done. But beyond that, after the installation of torrents is not started from the fact that for some reason the owner was root Downloads directory, not a transmission user and had to also change the directory owner.
Fun, so the transmission* rpm was not installed at the first attempt
What is the full rpm files installed
rpm -qa
What will it give?
rpm -qa
hplip-3.15.9-2.el7.x86_64
iprutils-2.4.13.1-1.el7.x86_64
basesystem-10.0-7.el7.centos.noarch
python-slip-dbus-0.4.0-2.el7.noarch
wget-1.14-13.el7.x86_64
mpfr-3.1.1-4.el7.x86_64
python-setuptools-0.9.8-4.el7.noarch
centos-release-scl-2-2.el7.centos.noarch
zlib-1.2.7-17.el7.x86_64
glibc-headers-2.17-157.el7_3.1.x86_64
python2-configargparse-0.11.0-1.el7.noarch
ivtv-firmware-20080701-26.el7.noarch
libtalloc-2.1.6-1.el7.x86_64
hiredis-0.12.1-1.el7.x86_64
python-enum34-1.0.4-1.el7.noarch
iwl2030-firmware-18.168.6.1-49.el7.noarch
libtevent-0.9.28-1.el7.x86_64
ntopng-2.4.160712-1303.x86_64
gpg-pubkey-8fae34bd-538f1e51
libdhash-0.4.3-27.el7.x86_64
perl-IO-Zlib-1.10-291.el7.noarch
perl-HTML-Format-2.10-7.el7.noarch
krb5-libs-1.14.1-27.el7_3.x86_64
elfutils-libelf-0.166-2.el7.x86_64
unbound-1.4.20-28.el7.x86_64
cups-libs-1.6.3-26.el7.x86_64
systemd-libs-219-30.el7_3.6.x86_64
freetype-2.4.11-12.el7.x86_64
perl-Razor-Agent-2.85-15.el7.x86_64
policycoreutils-2.5-11.el7_3.x86_64
p11-kit-0.20.7-3.el7.x86_64
freeze-2.5.0-16.el7.x86_64
rpm-4.11.3-21.el7.x86_64
device-mapper-1.02.135-1.el7_3.2.x86_64
GeoIP-1.5.0-11.el7.x86_64
perl-Sys-Hostname-Long-1.5-1.el7.noarch
php-intl-5.4.16-42.el7.x86_64
duc-1.4.2-1.ns7.x86_64
perl-Pod-Escapes-1.04-291.el7.noarch
perl-Archive-Tar-1.92-2.el7.noarch
perl-Net-Server-2.007-2.el7.noarch
sssd-krb5-common-1.14.0-43.el7_3.11.x86_64
perl-Exporter-5.68-3.el7.noarch
perl-Crypt-OpenSSL-Bignum-0.04-18.el7.x86_64
rpm-python-4.11.3-21.el7.x86_64
perl-Carp-1.26-244.el7.noarch
perl-MailTools-2.12-2.el7.noarch
sssd-1.14.0-43.el7_3.11.x86_64
perl-Data-Dumper-2.145-3.el7.x86_64
dovecot-antispam-0.0.49-3.ns7.x86_64
json-c-0.11-4.el7_0.x86_64
nethserver-duc-1.4.1-1.ns7.noarch
perl-Net-IPv4Addr-0.10-19.el7.noarch
nethserver-stephdl-1.0.2-1.ns7.sdl.noarch
NetworkManager-wifi-1.4.0-14.el7_3.x86_64
file-5.11-33.el7.x86_64
sssd-libwbclient-1.14.0-43.el7_3.11.x86_64
kernel-3.10.0-514.6.1.el7.x86_64
which-2.20-7.el7.x86_64
fail2ban-0.9.5-3.el7.noarch
mc-4.8.7-11.el7.x86_64
ca-certificates-2015.2.6-73.el7.noarch
perl-Params-Util-1.07-6.el7.x86_64
cronie-anacron-1.4.11-14.el7_2.1.x86_64
libSM-1.2.2-2.el7.x86_64
libxshmfence-1.2-1.el7.x86_64
perl-Net-FTP-AutoReconnect-0.3-11.el7.noarch
wpa_supplicant-2.0-20.el7.x86_64
net-snmp-libs-5.7.2-24.el7_2.1.x86_64
perl-Digest-HMAC-1.03-5.el7.noarch
perl-Class-Singleton-1.4-14.el7.noarch
grub2-tools-2.02-0.44.el7.centos.x86_64
libXt-1.1.4-6.1.el7.x86_64
perl-XML-NamespaceSupport-1.11-10.el7.noarch
nethserver-base-3.0.17-1.ns7.noarch
nethserver-yum-1.4.1-1.ns7.noarch
liberation-mono-fonts-1.07.2-15.el7.noarch
perl-Net-LibIDN-0.12-15.el7.x86_64
gutenprint-5.2.9-18.el7.x86_64
clamav-filesystem-0.99.2-1.el7.noarch
perl-HTTP-Message-6.06-6.el7.noarch
nethserver-cups-1.2.0-1.ns7.noarch
alsa-tools-firmware-1.1.0-1.el7.x86_64
perl-Net-Daemon-0.48-5.el7.noarch
less-458-9.el7.x86_64
libmcrypt-2.5.8-13.el7.x86_64
acl-2.2.51-12.el7.x86_64
php-pear-MDB2-Driver-mysqli-1.5.0-0.8.b4.el7.noarch
make-3.82-23.el7.x86_64
libX11-common-1.6.3-3.el7.noarch
perl-IO-Tty-1.10-11.el7.x86_64
graphite2-1.3.6-1.el7_2.x86_64
mesa-libGL-11.2.2-2.20160614.el7.x86_64
cups-client-1.6.3-26.el7.x86_64
coreutils-8.22-18.el7.x86_64
ufdbGuard-1.32.4-CentOS7.x86_64
cracklib-2.9.0-11.el7.x86_64
libpwquality-1.2.3-4.el7.x86_64
nethserver-phonehome-1.2.1-1.ns7.noarch
foomatic-filters-4.0.9-8.el7.x86_64
gettext-0.18.2.1-4.el7.x86_64
irqbalance-1.0.7-6.el7.x86_64
sane-backends-libs-1.0.24-9.el7.x86_64
grubby-8.28-18.el7.x86_64
parted-3.1-28.el7.x86_64
vsftpd-3.0.2-21.el7.x86_64
setup-2.8.71-7.el7.noarch
python-chardet-2.2.1-1.el7_1.noarch
tcpdump-4.5.1-3.el7.x86_64
nethserver-openvpn-1.4.4-1.ns7.noarch
mailcap-2.1.41-2.el7.noarch
yum-metadata-parser-1.1.4-10.el7.x86_64
passwd-0.79-4.el7.x86_64
nethserver-lightsquid-1.1.2-1.ns7.noarch
fontpackages-filesystem-1.44-8.el7.noarch
e2fsprogs-1.42.9-9.el7.x86_64
nss-softokn-freebl-3.16.2.3-14.4.el7.x86_64
python-backports-ssl_match_hostname-3.4.0.2-4.el7.noarch
patch-2.7.1-8.el7.x86_64
libmpc-1.0.1-3.el7.x86_64
ncurses-libs-5.9-13.20130511.el7.x86_64
python-ndg_httpsclient-0.3.2-1.el7.noarch
libsysfs-2.1.0-16.el7.x86_64
jemalloc-3.6.0-1.el7.x86_64
libselinux-2.5-6.el7.x86_64
python-parsedatetime-1.5-3.el7.noarch
iwl1000-firmware-39.31.5.1-49.el7.noarch
glibc-devel-2.17-157.el7_3.1.x86_64
popt-1.13-16.el7.x86_64
python-tdb-1.3.8-1.el7_2.x86_64
iwl3160-firmware-22.0.7.0-49.el7.noarch
pfring-dkms-6.4.1-718.noarch
chkconfig-1.7.2-1.el7.x86_64
python-psutil-2.2.1-1.el7.x86_64
iwl6050-firmware-41.28.5.1-49.el7.noarch
nut-client-2.7.2-3.el7.x86_64
libuuid-2.23.2-33.el7.x86_64
python-idna-2.0-1.el7.noarch
iwl6000g2b-firmware-17.168.5.2-49.el7.noarch
numactl-2.0.9-6.el7_2.x86_64
libxml2-2.9.1-6.el7_2.3.x86_64
python2-certbot-0.9.3-1.el7.noarch
iwl4965-firmware-228.61.2.24-49.el7.noarch
libldb-1.1.26-1.el7.x86_64
libssh2-1.4.3-10.el7_2.1.x86_64
gpg-pubkey-f2ee9d55-560cfc0a
clamav-data-empty-0.99.2-1.el7.noarch
libbasicobjects-0.1.1-27.el7.x86_64
perl-IO-Socket-SSL-1.94-5.el7.noarch
bind-license-9.9.4-38.el7_3.1.noarch
libevent-2.0.21-4.el7.x86_64
libcap-2.22-8.el7.x86_64
perl-HTML-Tree-5.03-2.el7.noarch
glibc-common-2.17-157.el7_3.1.x86_64
perl-version-0.99.07-2.el7.x86_64
gawk-4.0.2-4.el7.x86_64
fipscheck-lib-1.4.1-5.el7.x86_64
nss-sysinit-3.21.3-2.el7_3.x86_64
nethserver-unbound-1.1.0-1.ns7.noarch
glib2-2.46.2-4.el7.x86_64
nmap-ncat-6.40-7.el7.x86_64
libgcrypt-1.5.3-13.el7_3.1.x86_64
clamav-0.99.2-1.el7.x86_64
libidn-1.28-4.el7.x86_64
samba-common-4.4.4-12.el7_3.noarch
libmspack-0.5-0.4.alpha.el7.x86_64
lua-5.1.4-15.el7.x86_64
NetworkManager-1.4.0-14.el7_3.x86_64
p7zip-plugins-16.02-2.el7.x86_64
jansson-2.4-6.el7.x86_64
libcurl-7.29.0-35.el7.centos.x86_64
samba-common-libs-4.4.4-12.el7_3.x86_64
pyparsing-1.5.6-9.el7.noarch
diffutils-3.3-4.el7.x86_64
openldap-2.4.40-13.el7.x86_64
chrony-2.1.1-4.el7.centos.x86_64
perl-Digest-SHA1-2.13-9.el7.x86_64
file-libs-5.11-33.el7.x86_64
libuser-0.60-7.el7_1.x86_64
bind-utils-9.9.4-38.el7_3.1.x86_64
unzoo-4.4-16.el7.x86_64
gdbm-1.10-8.el7.x86_64
php-cli-5.4.16-42.el7.x86_64
shorewall-5.0.14.1-2.el7.noarch
p7zip-16.02-2.el7.x86_64
perl-Pod-Perldoc-3.20-4.el7.noarch
python-urlgrabber-3.10-8.el7.noarch
sssd-client-1.14.0-43.el7_3.11.x86_64
lrzip-0.616-5.el7.x86_64
perl-Pod-Usage-1.63-3.el7.noarch
pixman-0.34.0-1.el7.x86_64
sssd-common-1.14.0-43.el7_3.11.x86_64
lzop-1.03-10.el7.x86_64
perl-Storable-2.45-3.el7.x86_64
gpgme-1.3.2-5.el7.x86_64
sssd-ldap-1.14.0-43.el7_3.11.x86_64
perl-Time-Local-1.2300-2.el7.noarch
yum-plugin-fastestmirror-1.1.31-40.el7.noarch
sudo-1.8.6p7-21.el7_3.x86_64
perl-Socket-2.010-4.el7.x86_64
libipa_hbac-1.14.0-43.el7_3.11.x86_64
perl-PathTools-3.40-5.el7.x86_64
python-sssdconfig-1.14.0-43.el7_3.11.noarch
perl-JSON-2.59-2.el7.noarch
libndp-1.2-7.el7.x86_64
perl-Compress-Raw-Zlib-2.061-4.el7.x86_64
libXau-1.0.8-2.1.el7.x86_64
nethserver-ntp-1.1.1-1.ns7.noarch
perl-Sys-Syslog-0.33-3.el7.x86_64
shadow-utils-4.1.5.1-24.el7.x86_64
kpartx-0.4.9-99.el7_3.1.x86_64
perl-Digest-SHA-5.85-3.el7.x86_64
NetworkManager-team-1.4.0-14.el7_3.x86_64
perl-HTTP-Date-6.02-8.el7.noarch
libdaemon-0.14-7.el7.x86_64
mdadm-3.4-14.el7_3.1.x86_64
bind-libs-lite-9.9.4-38.el7_3.1.x86_64
xz-5.2.2-1.el7.x86_64
kmod-20-9.el7.x86_64
libpciaccess-0.13.4-3.el7_3.x86_64
e2fsprogs-libs-1.42.9-9.el7.x86_64
polkit-0.112-9.el7.x86_64
gpm-libs-1.20.7-5.el7.x86_64
p11-kit-trust-0.20.7-3.el7.x86_64
libICE-1.0.9-2.el7.x86_64
sysvinit-tools-2.88-14.dsf.el7.x86_64
cronie-1.4.11-14.el7_2.1.x86_64
perl-GD-2.49-3.el7.x86_64
hostname-3.13-3.el7.x86_64
initscripts-9.49.37-1.el7.x86_64
libfontenc-1.1.2-3.el7.x86_64
iptables-1.4.21-17.el7.x86_64
dnsmasq-2.66-21.el7.x86_64
libgusb-0.1.6-3.el7.x86_64
perl-File-Listing-6.04-7.el7.noarch
ppp-2.4.5-33.el7.x86_64
colord-libs-1.2.7-2.el7.x86_64
perl-XML-Filter-BufferText-1.01-17.el7.noarch
dracut-network-033-463.el7.x86_64
urw-fonts-2.4-16.el7.noarch
perl-IO-Compress-2.061-2.el7.noarch
plymouth-0.8.9-0.26.20140113.el7.centos.x86_64
perl-GDGraph3d-0.63-23.el7.noarch
perl-gettext-1.05-28.el7.x86_64
liberation-fonts-common-1.07.2-15.el7.noarch
perl-Mail-RFC822-Address-0.3-1.ns7.noarch
ghostscript-9.07-20.el7_3.1.x86_64
gutenprint-cups-5.2.9-18.el7.x86_64
perl-IO-Multiplex-1.13-6.el7.noarch
php-5.4.16-42.el7.x86_64
cups-filters-libs-1.0.35-21.el7.x86_64
libtiff-4.0.3-27.el7_3.x86_64
perl-URI-1.60-9.el7.noarch
squid-migration-script-3.5.20-2.el7_3.2.x86_64
transmission-daemon-2.92-1.el7.geekery.x86_64
perl-HTTP-Cookies-6.01-5.el7.noarch
ebtables-2.0.10-15.el7.x86_64
avahi-glib-0.6.31-17.el7.x86_64
perl-Font-AFM-1.20-13.el7.noarch
libsoup-2.48.1-6.el7.x86_64
squid-3.5.20-2.el7_3.2.x86_64
libxslt-1.1.28-5.el7.x86_64
libusb-0.1.4-3.el7.x86_64
dbus-glib-0.100-7.el7.x86_64
liboping-1.6.2-2.el7.x86_64
libdb-utils-5.3.21-19.el7.x86_64
php-pear-MDB2-2.5.0-0.9.b5.el7.noarch
mozjs17-17.0.0-19.el7.x86_64
libc-client-2007f-4.el7.1.x86_64
libselinux-utils-2.5-6.el7.x86_64
libX11-1.6.3-3.el7.x86_64
hplip-common-3.15.9-2.el7.x86_64
dialog-1.2-4.20130523.el7.x86_64
libXdamage-1.1.4-4.1.el7.x86_64
lockdev-1.0.4-0.13.20111007git.el7.x86_64
libmodman-2.0.1-8.el7.x86_64
mesa-libEGL-11.2.2-2.20160614.el7.x86_64
colord-1.2.7-2.el7.x86_64
libverto-0.2.5-4.el7.x86_64
libreport-filesystem-2.1.11-35.el7.centos.x86_64
perl-FCGI-0.74-8.el7.x86_64
python-libs-2.7.5-48.el7.x86_64
yum-utils-1.1.31-40.el7.noarch
openssl-1.0.1e-60.el7.x86_64
php-gd-5.4.16-42.el7.x86_64
python2-pyasn1-0.1.9-7.el7.noarch
ghostscript-cups-9.07-20.el7_3.1.x86_64
cracklib-dicts-2.9.0-11.el7.x86_64
php-mbstring-5.4.16-42.el7.x86_64
rdma-7.3_4.7_rc2-5.el7.noarch
openvpn-2.3.14-1.el7.x86_64
python-zope-interface-4.0.5-4.el7.x86_64
usbutils-007-5.el7.x86_64
collectd-5.7.1-1.el7.x86_64
pyOpenSSL-0.13.1-3.el7.x86_64
python-pyudev-0.15-7.el7_2.1.noarch
perl-Crypt-OpenSSL-RSA-0.28-7.el7.x86_64
perl-ExtUtils-ParseXS-3.18-2.el7.noarch
perl-Mail-DKIM-0.39-8.el7.noarch
clucene-core-2.3.3.4-11.el7.x86_64
dovecot-pigeonhole-2.2.10-7.el7.x86_64
nethserver-mail-common-1.6.2-1.ns7.noarch
gpg-pubkey-f5194398-527516a9
samba-4.4.4-12.el7_3.x86_64
nethserver-samba-2.0.4-1.ns7.noarch
fail2ban-server-0.9.5-3.el7.noarch
fail2ban-shorewall-0.9.5-3.el7.noarch
nethserver-crontabmanager-0.0.7-1.ns7.sdl.noarch
perl-Module-Runtime-0.013-4.el7.noarch
perl-Package-DeprecationManager-0.13-7.el7.noarch
perl-Package-Stash-XS-0.26-3.el7.x86_64
perl-Time-ParseDate-2015.103-1.el7.noarch
perl-DateTime-1.04-5.el7.x86_64
perl-XML-RSS-1.54-1.el7.noarch
nethserver-sssd-1.1.6-1.ns7.noarch
nethserver-release-7-1.ns7.noarch
rsync-3.0.9-17.el7.x86_64
libieee1284-0.2.11-15.el7.x86_64
dracut-config-rescue-033-463.el7.x86_64
pytalloc-2.1.6-1.el7.x86_64
centos-release-7-3.1611.el7.centos.x86_64
nethserver-vsftpd-1.1.0-1.ns7.noarch
screen-4.1.0-0.23.20120314git3c2946.el7_2.x86_64
python2-mock-1.0.1-9.el7.noarch
libselinux-python-2.5-6.el7.x86_64
kbd-legacy-1.15.5-12.el7.noarch
perl-List-MoreUtils-0.33-9.el7.x86_64
btrfs-progs-4.4.1-1.el7.x86_64
ncurses-base-5.9-13.20130511.el7.noarch
bandwidthd-2.0.1-35.ns7.x86_64
tmpwatch-2.11-5.el7.x86_64
python-urllib3-1.10.2-2.el7_1.noarch
libstdc++-4.8.5-11.el7.x86_64
cpp-4.8.5-11.el7.x86_64
traceroute-2.0.22-2.el7.x86_64
python-iniparse-0.4-9.el7.noarch
libsepol-2.5-6.el7.x86_64
redis-2.8.19-2.el7.x86_64
iwl2000-firmware-18.168.6.1-49.el7.noarch
newt-python-0.52.15-4.el7.x86_64
info-5.1-4.el7.x86_64
gcc-4.8.5-11.el7.x86_64
iwl6000-firmware-9.221.4.1-49.el7.noarch
python-ply-3.4-10.el7.noarch
dbus-libs-1.6.12-17.el7.x86_64
pfring-6.4.1-718.x86_64
iwl3945-firmware-15.32.2.9-49.el7.noarch
python2-pyrfc3339-1.0-2.el7.noarch
xz-libs-5.2.2-1.el7.x86_64
nut-2.7.2-3.el7.x86_64
iwl135-firmware-18.168.6.1-49.el7.noarch
python2-cryptography-1.3.1-3.el7.x86_64
libtdb-1.3.8-1.el7_2.x86_64
libsodium-1.0.5-1.el7.x86_64
iwl5000-firmware-8.83.5.1_1-49.el7.noarch
grep-2.20-2.el7.x86_64
nethserver-nut-1.3.0-1.ns7.noarch
gpg-pubkey-b6792c39-53c4fbdd
mariadb-libs-5.5.52-1.el7.x86_64
libref_array-0.1.5-27.el7.x86_64
clamav-lib-0.99.2-1.el7.x86_64
gpg-pubkey-39baf5c1-56bb3d4a
perl-Net-HTTP-6.06-2.el7.noarch
libattr-2.4.46-12.el7.x86_64
pax-3.4-19.el7.x86_64
bash-4.2.46-21.el7_3.x86_64
perl-XML-Twig-3.44-2.el7.noarch
audit-libs-2.6.5-3.el7.x86_64
perl-Convert-BinHex-1.119-20.el7.noarch
nss-3.21.3-2.el7_3.x86_64
fipscheck-1.4.1-5.el7.x86_64
pkgconfig-0.27.1-4.el7.x86_64
perl-IO-Socket-INET6-2.69-5.el7.noarch
libnl3-3.2.28-3.el7_3.x86_64
perl-GSSAPI-0.28-9.el7.x86_64
clamav-unofficial-sigs-3.7.2-1.el7.noarch
libgudev1-219-30.el7_3.6.x86_64
cabextract-1.5-1.el7.x86_64
NetworkManager-libnm-1.4.0-14.el7_3.x86_64
mailx-12.5-12.el7_0.x86_64
gmp-6.0.0-12.el7_1.x86_64
arj-3.10.22-22.el7.x86_64
selinux-policy-3.13.1-102.el7_3.13.noarch
sqlite-3.7.17-8.el7.x86_64
systemtap-sdt-devel-3.0-7.el7.x86_64
libsmbclient-4.4.4-12.el7_3.x86_64
php-common-5.4.16-42.el7.x86_64
apr-1.4.8-3.el7.x86_64
perl-Error-0.17020-2.el7.noarch
bind-libs-9.9.4-38.el7_3.1.x86_64
dhcp-common-4.2.5-47.el7.centos.x86_64
libedit-3.0-12.20121213cvs.el7.x86_64
nomarch-1.4-11.el7.x86_64
shorewall-core-5.0.14.1-2.el7.noarch
libnfsidmap-0.25-15.el7.x86_64
perl-podlators-2.5.1-3.el7.noarch
procmail-3.22-35.el7.x86_64
libsss_nss_idmap-1.14.0-43.el7_3.11.x86_64
logrotate-3.8.6-12.el7.x86_64
perl-Encode-2.51-7.el7.x86_64
perl-Test-Harness-3.28-3.el7.noarch
libsss_sudo-1.14.0-43.el7_3.11.x86_64
hardlink-1.0-19.el7.x86_64
perl-threads-1.87-4.el7.x86_64
sssd-ad-1.14.0-43.el7_3.11.x86_64
pygpgme-0.3-9.el7.x86_64
perl-Filter-1.49-3.el7.x86_64
vim-minimal-7.4.160-1.el7_3.1.x86_64
yum-3.4.3-150.el7.centos.noarch
perl-Scalar-List-Utils-1.27-248.el7.x86_64
python-perf-3.10.0-514.6.1.el7.x86_64
perl-File-Path-2.09-2.el7.noarch
bridge-utils-1.5-9.el7.x86_64
perl-5.16.3-291.el7.x86_64
firewalld-0.4.3.2-8.1.el7_3.noarch
libpipeline-1.2.3-3.el7.x86_64
perl-XML-SAX-Base-1.08-7.el7.noarch
nethserver-firewall-base-3.1.6-1.ns7.noarch
libxcb-1.11-4.el7.x86_64
libmnl-1.0.3-7.el7.x86_64
kernel-tools-3.10.0-514.6.1.el7.x86_64
libutempter-1.1.6-4.el7.x86_64
perl-Digest-MD5-2.52-3.el7.x86_64
openssh-clients-6.6.1p1-33.el7_3.x86_64
authconfig-6.2.8-14.el7.x86_64
perl-TimeDate-2.30-2.el7.noarch
microcode_ctl-2.1-16.1.el7_3.x86_64
teamd-1.25-4.el7.x86_64
nss-softokn-3.16.2.3-14.4.el7.x86_64
nss-tools-3.21.3-2.el7_3.x86_64
kmod-libs-20-9.el7.x86_64
xfsprogs-4.5.0-9.el7_3.x86_64
libgomp-4.8.5-11.el7.x86_64
epel-release-7-9.noarch
polkit-pkla-compat-0.1-4.el7.x86_64
libtasn1-3.8-3.el7.x86_64
lcms2-2.6-3.el7.x86_64
newt-0.52.15-4.el7.x86_64
gd-2.0.35-26.el7.x86_64
nethserver-lib-2.2.1-1.ns7.noarch
lzo-2.06-8.el7.x86_64
php-mysql-5.4.16-42.el7.x86_64
dhclient-4.2.5-47.el7.centos.x86_64
libnetfilter_conntrack-1.0.4-2.el7.x86_64
libecap-1.0.0-1.el7.x86_64
postfix-2.10.1-6.el7.x86_64
libteam-1.25-4.el7.x86_64
foomatic-db-filesystem-4.0-40.20130911.el7.noarch
smartmontools-6.2-7.el7.x86_64
ipset-6.19-6.el7.x86_64
ghostscript-fonts-5.50-32.el7.noarch
perl-Compress-Raw-Bzip2-2.061-3.el7.x86_64
perl-GDGraph-1.44-15.el7.noarch
mesa-libgbm-11.2.2-2.20160614.el7.x86_64
perl-XML-Parser-2.41-10.el7.x86_64
libwebp-0.3.0-3.el7.x86_64
nethserver-hosts-1.2.1-1.ns7.noarch
perl-NetAddr-IP-4.069-3.el7.x86_64
nethserver-bandwidthd-1.0.1-1.ns7.noarch
perl-Text-Template-1.45-12.el7.noarch
python-pillow-2.0.0-19.gitd1c6db8.el7.x86_64
oddjob-0.31.5-4.el7.x86_64
perl-Business-ISBN-2.06-2.el7.noarch
cups-1.6.3-26.el7.x86_64
fxload-2002_04_11-16.el7.x86_64
perl-HTTP-Negotiate-6.01-5.el7.noarch
transmission-2.92-1.el7.geekery.x86_64
rrdtool-1.4.8-9.el7.x86_64
trousers-0.3.13-1.el7.x86_64
perl-Convert-ASN1-0.26-4.el7.noarch
perl-DBI-1.627-4.el7.x86_64
cyrus-sasl-plain-2.1.26-20.el7_2.x86_64
perl-DBD-MySQL-4.023-5.el7.x86_64
php-ldap-5.4.16-42.el7.x86_64
tar-1.26-31.el7.x86_64
php-pear-1.9.4-21.el7.noarch
avahi-libs-0.6.31-17.el7.x86_64
php-pear-Net-Curl-1.2.5-10.el7.noarch
libthai-0.1.14-9.el7.x86_64
libzip-0.10.1-8.el7.x86_64
mariadb-server-5.5.52-1.el7.x86_64
libXext-1.3.3-3.el7.x86_64
ncurses-5.9-13.20130511.el7.x86_64
nethserver-mysql-1.1.1-1.ns7.noarch
libXft-2.3.2-2.el7.x86_64
libicu-50.1.2-15.el7.x86_64
color-filesystem-1-13.el7.noarch
cairo-1.14.2-1.el7.x86_64
c-ares-1.10.0-3.el7.x86_64
gdb-7.6.1-94.el7.x86_64
openssl-libs-1.0.1e-60.el7.x86_64
libxml2-python-2.9.1-6.el7_2.3.x86_64
kbd-1.15.5-12.el7.x86_64
gzip-1.5-8.el7.x86_64
t1lib-5.1.2-14.el7.x86_64
python-six-1.9.0-2.el7.noarch
cups-filters-1.0.35-21.el7.x86_64
nethserver-openssh-1.2.0-1.ns7.noarch
fontconfig-2.10.95-10.el7.x86_64
foomatic-db-4.0-40.20130911.el7.noarch
nethserver-smartd-1.1.0-1.ns7.noarch
pkcs11-helper-1.11-3.el7.x86_64
kexec-tools-2.0.7-50.el7.x86_64
libmount-2.23.2-33.el7.x86_64
yajl-2.0.4-4.el7.x86_64
pygobject3-base-3.14.0-3.el7.x86_64
nethserver-collectd-3.0.4-1.ns7.noarch
aic94xx-firmware-30-6.el7.noarch
plymouth-core-libs-0.8.9-0.26.20140113.el7.centos.x86_64
gdbm-devel-1.10-8.el7.x86_64
perl-ExtUtils-Manifest-1.61-244.el7.noarch
perl-devel-5.16.3-291.el7.x86_64
perl-MIME-tools-5.505-1.el7.noarch
dovecot-2.2.10-7.el7.x86_64
perl-DBD-SQLite-1.39-3.el7.x86_64
nethserver-mail-server-1.10.7-1.ns7.noarch
mod_authnz_pam-0.9.3-5.el7_2.x86_64
nethserver-backup-config-1.5.2-1.ns7.noarch
fail2ban-sendmail-0.9.5-3.el7.noarch
perl-Try-Tiny-0.12-2.el7.noarch
perl-Module-Implementation-0.06-6.el7.noarch
perl-Data-OptList-0.107-9.el7.noarch
perl-Package-Stash-0.34-2.el7.noarch
libarchive-3.1.2-10.el7_2.x86_64
perl-DateTime-TimeZone-1.63-2.el7.noarch
BackupPC-3.3.1-5.el7.x86_64
nethserver-lang-en-1.1.7-1.ns7.noarch
cups-ipptool-1.6.3-26.el7.x86_64
hpijs-3.15.9-2.el7.x86_64
libgcc-4.8.5-11.el7.x86_64
pyliblzma-0.5.3-11.el7.x86_64
python-ipaddress-1.0.16-2.el7.noarch
man-db-2.6.3-9.el7.x86_64
nethserver-nextcloud-1.0.4-1.ns7.noarch
centos-release-scl-rh-2-2.el7.centos.noarch
python-slip-0.4.0-2.el7.noarch
openldap-servers-2.4.40-13.el7.x86_64
linux-firmware-20160830-49.git7534e19.el7.noarch
pyxattr-0.5.1-5.el7.x86_64
nethserver-nethforge-release-7-0.3.ns7.noarch
python-requests-2.6.0-1.el7_1.noarch
strace-4.8-11.el7.x86_64
OpenIPMI-modalias-2.0.19-15.el7.x86_64
pcre-8.32-15.el7_2.1.x86_64
python-zope-event-4.0.3-2.el7.noarch
kernel-headers-3.10.0-514.6.1.el7.x86_64
libcom_err-1.42.9-9.el7.x86_64
pytz-2012d-5.el7.noarch
iwl5150-firmware-8.24.2.2-49.el7.noarch
kernel-devel-3.10.0-514.6.1.el7.x86_64
python-pycparser-2.14-1.el7.noarch
iwl7260-firmware-22.0.7.0-49.el7.noarch
ntopng-data-2.4.160712-1303.noarch
bzip2-libs-1.0.6-13.el7.x86_64
python-dateutil-1.5-7.el7.noarch
iwl7265-firmware-22.0.7.0-49.el7.noarch
openpgm-5.2.122-2.el7.x86_64
libdb-5.3.21-19.el7.x86_64
python2-acme-0.9.3-1.el7.noarch
iwl6000g2a-firmware-17.168.5.3-49.el7.noarch
zeromq-4.1.4-5.el7.x86_64
gpg-pubkey-f4a80eb5-53a7ff4b
nethserver-firewall-base-ui-3.1.6-1.ns7.noarch
readline-6.2-9.el7.x86_64
gpg-pubkey-352c64e5-52ae6884
clamav-server-0.99.2-1.el7.x86_64
libcollection-0.6.2-27.el7.x86_64
perl-libwww-perl-6.05-2.el7.noarch
glibc-2.17-157.el7_3.1.x86_64
perl-Socket6-0.23-15.el7.x86_64
libcap-ng-0.7.5-4.el7.x86_64
perl-Net-DBus-1.1.0-4.ns7.x86_64
nss-util-3.21.3-1.1.el7_3.x86_64
unbound-libs-1.4.20-28.el7.x86_64
libffi-3.0.13-18.el7.x86_64
perl-Authen-Krb5-1.9-1.ns7.x86_64
libsemanage-2.5-5.1.el7_3.x86_64
clamav-server-systemd-0.99.2-1.el7.noarch
libgpg-error-1.12-3.el7.x86_64
perl-Authen-SASL-2.15-10.el7.noarch
systemd-219-30.el7_3.6.x86_64
nethserver-antivirus-1.2.0-1.ns7.noarch
binutils-2.25.1-22.base.el7.x86_64
samba-client-libs-4.4.4-12.el7_3.x86_64
perl-Unix-Syslog-1.1-17.el7.x86_64
cpio-2.11-24.el7.x86_64
openssh-6.6.1p1-33.el7_3.x86_64
perl-DB_File-1.830-6.el7.x86_64
elfutils-libs-0.166-2.el7.x86_64
rpm-libs-4.11.3-21.el7.x86_64
samba-common-tools-4.4.4-12.el7_3.x86_64
perl-Archive-Zip-1.30-11.el7.noarch
groff-base-1.22.2-8.el7.x86_64
device-mapper-libs-1.02.135-1.el7_3.2.x86_64
perl-Mail-SPF-2.8.0-4.el7.noarch
psmisc-22.20-11.el7.x86_64
php-xml-5.4.16-42.el7.x86_64
krb5-workstation-1.14.1-27.el7_3.x86_64
portreserve-0.0.5-11.el7.x86_64
perl-HTTP-Tiny-0.033-3.el7.noarch
adcli-0.8.1-3.el7.x86_64
libsss_autofs-1.14.0-43.el7_3.11.x86_64
perl-Package-Constants-0.02-291.el7.noarch
perl-Text-ParseWords-3.29-4.el7.noarch
alsa-lib-1.1.1-1.el7.x86_64
tdb-tools-1.3.8-1.el7_2.x86_64
perl-Crypt-OpenSSL-Random-0.04-21.el7.x86_64
perl-libs-5.16.3-291.el7.x86_64
pth-2.0.7-23.el7.x86_64
sssd-common-pac-1.14.0-43.el7_3.11.x86_64
perl-BerkeleyDB-0.51-4.el7.x86_64
perl-Time-HiRes-1.9725-3.el7.x86_64
rpm-build-libs-4.11.3-21.el7.x86_64
sssd-proxy-1.14.0-43.el7_3.11.x86_64
perl-ExtUtils-Install-1.58-291.el7.noarch
perl-threads-shared-1.43-6.el7.x86_64
yum-plugin-changelog-1.1.31-40.el7.noarch
nethserver-lsm-1.2.2-1.ns7.noarch
perl-File-Temp-0.23.01-3.el7.noarch
numactl-libs-2.0.9-6.el7_2.x86_64
firewalld-filesystem-0.4.3.2-8.1.el7_3.noarch
perl-Getopt-Long-2.40-2.el7.noarch
libpath_utils-0.2.1-27.el7.x86_64
python-firewall-0.4.3.2-8.1.el7_3.noarch
perl-LWP-MediaTypes-6.02-2.el7.noarch
lsscsi-0.27-4.el7.x86_64
tuned-2.7.1-3.el7_3.1.noarch
libpcap-1.5.3-8.el7.x86_64
ustr-1.0.4-16.el7.x86_64
nethserver-dnsmasq-1.6.3-1.ns7.noarch
perl-Digest-1.17-245.el7.noarch
util-linux-2.23.2-33.el7.x86_64
openssh-server-6.6.1p1-33.el7_3.x86_64
perl-Encode-Locale-1.03-5.el7.noarch
NetworkManager-tui-1.4.0-14.el7_3.x86_64
apr-util-1.5.2-6.el7.x86_64
qrencode-libs-3.4.1-3.el7.x86_64
libnl3-cli-3.2.28-3.el7_3.x86_64
libcroco-0.6.8-5.el7.x86_64
cryptsetup-libs-1.7.2-1.el7.x86_64
libunistring-0.9.3-9.el7.x86_64
dbus-1.6.12-17.el7.x86_64
python2-simplejson-3.10.0-1.el7.x86_64
mesa-libglapi-11.2.2-2.20160614.el7.x86_64
httpd-2.4.6-45.el7.centos.x86_64
libjpeg-turbo-1.2.90-5.el7.x86_64
slang-2.2.4-11.el7.x86_64
crontabs-1.11-6.20121102git.el7.noarch
libtool-ltdl-2.4.2-21.el7_2.x86_64
tcp_wrappers-libs-7.6-77.el7.x86_64
hwdata-0.252-8.4.el7.x86_64
php-pdo-5.4.16-42.el7.x86_64
ethtool-4.5-3.el7.x86_64
mod_ssl-2.4.6-45.el7.centos.x86_64
poppler-data-0.4.6-3.el7.noarch
gettext-libs-0.18.2.1-4.el7.x86_64
os-prober-1.58-9.el7.x86_64
openjpeg-libs-1.5.1-10.el7.x86_64
ipset-libs-6.19-6.el7.x86_64
rp-pppoe-3.11-5.el7.x86_64
xorg-x11-font-utils-7.5-20.el7.x86_64
perl-Env-1.04-2.el7.noarch
libdrm-2.4.67-3.el7.x86_64
perl-GDTextUtil-0.86-23.el7.noarch
perl-XML-SAX-Writer-0.53-4.el7.noarch
pciutils-3.5.1-1.el7.x86_64
libv4l-0.9.5-4.el7.x86_64
perl-Text-Soundex-3.04-4.el7.x86_64
nethserver-httpd-3.1.1-1.ns7.noarch
jbigkit-libs-2.0-11.el7.x86_64
nethserver-ntopng-1.4.1-1.ns7.noarch
perl-IO-Socket-IP-0.21-4.el7.noarch
poppler-utils-0.26.5-16.el7.x86_64
cups-lpd-1.6.3-26.el7.x86_64
perl-Business-ISBN-Data-20120719.001-2.el7.noarch
oddjob-mkhomedir-0.31.5-4.el7.x86_64
nethserver-avahi-1.1.0-1.ns7.noarch
perl-HTML-Parser-3.71-4.el7.x86_64
alsa-firmware-1.0.28-2.el7.noarch
dejavu-sans-mono-fonts-2.33-6.el7.noarch
perl-WWW-RobotRules-6.02-5.el7.noarch
gnutls-3.3.24-1.el7.x86_64
perl-PlRPC-0.2020-14.el7.noarch
nettle-2.7.1-8.el7.x86_64
lsm-1.0.5-1.el7.lux.x86_64
gsettings-desktop-schemas-3.14.2-1.el7.x86_64
libestr-0.1.9-2.el7.x86_64
php-mcrypt-5.4.16-7.el7.x86_64
php-process-5.4.16-42.el7.x86_64
pinentry-0.8.1-17.el7.x86_64
php-smbclient-0.8.0-1.el7.x86_64
libpng-1.5.13-7.el7_2.x86_64
kbd-misc-1.15.5-12.el7.noarch
mariadb-5.5.52-1.el7.x86_64
libXrender-0.9.8-2.1.el7.x86_64
perl-Expect-1.21-14.el7.noarch
harfbuzz-0.9.36-1.el7.x86_64
libXxf86vm-1.1.3-2.1.el7.x86_64
bc-1.06.95-13.el7.x86_64
snappy-1.1.0-3.el7.x86_64
pango-1.36.8-2.el7.x86_64
python-kitchen-1.1.1-5.el7.noarch
lightsquid-apache-1.8-18.el7.lux.noarch
libblkid-2.23.2-33.el7.x86_64
nethserver-squidguard-1.6.2-1.ns7.noarch
python-decorator-3.4.0-3.el7.noarch
cups-filesystem-1.6.3-26.el7.noarch
centos-logos-70.0.6-3.el7.centos.noarch
foomatic-db-ppds-4.0-40.20130911.el7.noarch
pam-1.1.8-18.el7.x86_64
nethserver-mail-smarthost-0.1.0-1.ns7.noarch
avahi-0.6.31-17.el7.x86_64
perl-Authen-PAM-0.16-16.el7.x86_64
grub2-2.02-0.44.el7.centos.x86_64
foomatic-4.0.9-8.el7.x86_64
python-configobj-4.7.2-7.el7.noarch
audit-2.6.5-3.el7.x86_64
collectd-ping-5.7.1-1.el7.x86_64
libusbx-1.0.20-1.el7.x86_64
biosdevname-0.7.2-1.el7.x86_64
hplip-libs-3.15.9-2.el7.x86_64
perl-Net-SMTP-SSL-1.01-13.el7.noarch
perl-Convert-TNEF-0.18-2.el7.noarch
dovecot-deleted-to-trash-0.6-3.ns7.x86_64
altermime-0.3.10-10.el7.x86_64
nethserver-mail-filter-1.4.3-1.ns7.noarch
nethserver-ibays-3.0.3-1.ns7.noarch
perl-Email-Valid-1.198-1.el7.noarch
fail2ban-firewalld-0.9.5-3.el7.noarch
dokuwiki-20160626a-1.ns7.sdl.noarch
perl-Sub-Install-0.926-6.el7.noarch
perl-Params-Validate-1.08-4.el7.x86_64
perl-File-RsyncP-0.74-2.el7.x86_64
perl-Class-Load-0.20-3.el7.noarch
samba-client-4.4.4-12.el7_3.x86_64
perl-DateTime-Format-W3CDTF-0.06-5.el7.noarch
nethserver-BackupPC-1.1.0-1.ns7.sdl.noarch
nethserver-httpd-admin-2.0.7-1.ns7.noarch
collectd-nut-5.7.1-1.el7.x86_64
filesystem-3.2-21.el7.x86_64
nethserver-cgp-2.1.2-1.ns7.noarch
deltarpm-3.6-3.el7.x86_64
openldap-clients-2.4.40-13.el7.x86_64
python-backports-1.0-8.el7.x86_64
lsof-4.87-4.el7.x86_64
freeipmi-1.2.9-8.el7.x86_64
python-zope-component-4.1.0-1.el7.noarch
rootfiles-8.1-11.el7.noarch
nspr-4.11.0-1.el7_2.x86_64
dkms-2.3-1.20161202gitde1dca9.el7.noarch
python-cffi-1.6.0-5.el7.x86_64
iwl100-firmware-39.31.5.1-49.el7.noarch
sed-4.2.2-5.el7.x86_64
libnetfilter_queue-1.0.2-2.el7.x86_64
python2-dialog-3.3.0-6.el7.noarch
iwl105-firmware-18.168.6.1-49.el7.noarch
keyutils-libs-1.5.8-3.el7.x86_64
perl-Net-DNS-0.72-6.el7.x86_64
perl-Net-SSLeay-1.55-4.el7.x86_64
tzdata-2016j-1.el7.noarch
libacl-2.2.51-12.el7.x86_64
ldns-1.6.16-10.el7.x86_64
httpd-tools-2.4.6-45.el7.centos.x86_64
libsss_idmap-1.14.0-43.el7_3.11.x86_64
shared-mime-info-1.1-9.el7.x86_64
clamav-update-0.99.2-1.el7.x86_64
perl-LDAP-0.56-5.el7.noarch
libwbclient-4.4.4-12.el7_3.x86_64
cyrus-sasl-lib-2.1.26-20.el7_2.x86_64
bzip2-1.0.6-13.el7.x86_64
samba-libs-4.4.4-12.el7_3.x86_64
findutils-4.5.11-5.el7.x86_64
perl-Convert-UUlib-1.5-1.el7.x86_64
dhcp-libs-4.2.5-47.el7.centos.x86_64
libkadm5-1.14.1-27.el7_3.x86_64
perl-parent-0.225-244.el7.noarch
libdb-devel-5.3.21-19.el7.x86_64
python-pycurl-7.19.0-19.el7.x86_64
kernel-tools-libs-3.10.0-514.6.1.el7.x86_64
perl-macros-5.16.3-291.el7.x86_64
perl-Encode-Detect-1.01-13.el7.x86_64
gnupg2-2.0.22-4.el7.x86_64
sssd-krb5-1.14.0-43.el7_3.11.x86_64
perl-constant-1.27-2.el7.noarch
perl-ExtUtils-MakeMaker-6.68-3.el7.noarch
dmidecode-3.0-2.el7.x86_64
sssd-ipa-1.14.0-43.el7_3.11.x86_64
perl-Pod-Simple-3.28-4.el7.noarch
spamassassin-3.4.0-2.el7.x86_64
libini_config-1.3.0-27.el7.x86_64
pciutils-libs-3.5.1-1.el7.x86_64
amavisd-new-2.10.1-5.el7.noarch
selinux-policy-targeted-3.13.1-102.el7_3.13.noarch
perl-HTML-Tagset-3.20-15.el7.noarch
virt-what-1.13-8.el7.x86_64
systemd-sysv-219-30.el7_3.6.x86_64
libassuan-2.1.0-3.el7.x86_64
systemd-python-219-30.el7_3.6.x86_64
dracut-033-463.el7.x86_64
expat-2.1.0-10.el7_3.x86_64
libss-1.42.9-9.el7.x86_64
nethserver-dokuwiki-0.1.0-1.ns7.sdl.noarch
libXpm-3.5.11-3.el7.x86_64
libnfnetlink-1.0.1-4.el7.x86_64
perl-DateTime-Locale-0.45-6.el7.noarch
iputils-20160308-8.el7.x86_64
libexif-0.6.21-6.el7.x86_64
iproute-3.10.0-74.el7.x86_64
perl-Net-FTP-RetrHandle-0.2-11.el7.noarch
net-tools-2.0-0.17.20131004git.el7.x86_64
libXfont-1.5.1-2.el7.x86_64
perl-IO-stringy-2.110-22.el7.noarch
perl-DateTime-Format-Mail-0.3001-17.el7.noarch
plymouth-scripts-0.8.9-0.26.20140113.el7.centos.x86_64
lightsquid-1.8-18.el7.lux.noarch
perl-Text-Unidecode-0.04-20.el7.noarch
nethserver-directory-3.1.3-1.ns7.noarch
nethserver-php-1.2.0-1.ns7.noarch
poppler-0.26.5-16.el7.x86_64
perl-IO-HTML-1.00-2.el7.noarch
nethserver-fail2ban-0.1.3-2.ns7.sdl.noarch
realmd-0.16.1-9.el7.x86_64
dejavu-fonts-common-2.33-6.el7.noarch
perl-HTTP-Daemon-6.01-5.el7.noarch
glib-networking-2.42.0-1.el7.x86_64
nethserver-squid-1.5.2-1.ns7.noarch
gobject-introspection-1.42.0-1.el7.x86_64
libaio-0.3.109-13.el7.x86_64
tokyocabinet-1.4.48-3.el7.x86_64
php-imap-5.4.16-7.el7.x86_64
libXfixes-5.0.1-2.1.el7.x86_64
libgphoto2-2.5.2-3.el7.x86_64
libproxy-0.4.11-10.el7.x86_64
perl-CGI-3.63-4.el7.noarch
python-2.7.5-48.el7.x86_64
rsyslog-7.4.7-16.el7.x86_64
qpdf-libs-5.0.1-3.el7.x86_64
dbus-python-1.1.1-9.el7.x86_64
nethserver-letsencrypt-1.1.3-1.ns7.noarch
nextcloud-10.0.2-1.ns7.noarch
procps-ng-3.3.10-10.el7.x86_64
kernel-3.10.0-514.el7.x86_64
collectd-rrdtool-5.7.1-1.el7.x86_64
cyrus-sasl-gssapi-2.1.26-20.el7_2.x86_64
Sorry wrong start
rpm -qa | grep nethserver
# rpm -qa | grep nethserver
Nice to see some of my work on your server :wink:
I’m at the fosdem, i cannot dive yet now, i will look tomorrow if the plane lands safely
Good luck to you flight and landing!
Worked on the spec file, it should not come again, I hope :slight_smile:
Everything seems to be now properly installed:
# yum install nethserver-transmission --enablerepo=stephdl
Resolving Dependencies
--> Running transaction check
---> Package nethserver-transmission.noarch 0:1.1.1-2.ns7.sdl will be installed
--> Processing Dependency: transmission-daemon for package: nethserver-transmission-1.1.1-2.ns7.sdl.noarch
--> Processing Dependency: transmission-common for package: nethserver-transmission-1.1.1-2.ns7.sdl.noarch
--> Processing Dependency: transmission-cli for package: nethserver-transmission-1.1.1-2.ns7.sdl.noarch
--> Processing Dependency: transmission for package: nethserver-transmission-1.1.1-2.ns7.sdl.noarch
Thanks!
