me too, remarkable teamwork guys!
Oh yes. This was a real flow.
Even if I think that my part was just to find the bug and the work was done by the real Nethserver Experts
Cannot find the updated package in the repo.
My bad, I pushed the rpm under NS 6.8
Now itβs in the right repo: http://packages.nethserver.org/nethserver/7.2.1511/testing/x86_64/Packages/nethserver-roundcubemail-1.2.4-1.9.g849b0ce.ns7.noarch.rpm
Thanks!
With the new package on a clean system, opening roundcube says: config.inc.php was not found
Error in /etc/e-smith/db/networks/migrate//trafficshaping.el7 when expanding templates (see previous post)
/var/log/messages excerpts:
systemd: Started MariaDB database server.
esmith::event[3035]: /usr/bin/mysql_secure_installation: line 379: find_mysql_client: command not found
systemd: Cannot add dependency job for unit clamd@amavisd.service, ignoring: Unit clamd@amavisd.service failed to load: No such file or directory.
esmith::event[4045]: ERROR in /etc/e-smith/templates//etc/roundcubemail/config.inc.php/50ADDRESSBOOK_SETTINGS: Program fragment delivered error <<Can't locate object method "port" via package "URI::_generic" at /usr/share/perl5/vendor_perl/NethServer/SSSD.pm line 134.>> at template line 31
esmith::event[4045]: ERROR: Template processing failed for //etc/roundcubemail/config.inc.php: 1 fragment generated errors
esmith::event[4045]: at /etc/e-smith/events/actions/generic_template_expand line 64.
esmith::event[4045]: [WARNING] expansion of /etc/roundcubemail/config.inc.php failed
esmith::event[4045]: Action: /etc/e-smith/events/actions/generic_template_expand FAILED: 1 [0.355151]
esmith::event[4045]: Event: nethserver-roundcubemail-update FAILED
systemd: Starting Cleanup of Temporary Directories...
systemd-tmpfiles: [/usr/lib/tmpfiles.d/amavisd-new.conf:2] Unknown group 'clamupdate'.
systemd: systemd-tmpfiles-clean.service: main process exited, code=exited, status=1/FAILURE
systemd: Failed to start Cleanup of Temporary Directories.
systemd: Unit systemd-tmpfiles-clean.service entered failed state.
systemd: systemd-tmpfiles-clean.service failed.
What is your nethserver-sssd version?
The one from base repo (nethserver-sssd-1.0.0.-1.ns7.arch), not from testing.
Could you try the testing one?
NS up to date with testing updates, without a previous roundcube install.
Installation was successful. Redirection worked as expected.
Dec 8 18:46:23 test esmith::event[2479]: /usr/bin/mysql_secure_installation: line 379: find_mysql_client: command not found Dec 8 18:46:23 test esmith::event[2479]: Action: /etc/e-smith/events/nethserver-mysql-update/S02nethserver-mysql-conf SUCCESS [3.945959] Dec 8 18:46:29 test systemd: Cannot add dependency job for unit clamd@amavisd.service, ignoring: Unit clamd@amavisd.service failed to load: No such file or directory. Dec 8 18:46:30 test esmith::event[3110]: [INFO] amavisd has been started Dec 8 18:46:36 test esmith::event[3895]: WARNING in /etc/e-smith/templates//etc/lsm/lsm.conf/20providers: Use of uninitialized value $esmith::__TEMPLATE__::1::i in concatenation (.) or string at /etc/e-smith/templates//etc/lsm/lsm.conf/20providers line 22. Dec 8 18:46:36 test esmith::event[3895]: WARNING: Template processing succeeded for //etc/lsm/lsm.conf: 2 fragments generated warnings Dec 8 18:46:36 test esmith::event[3895]: at /etc/e-smith/events/actions/generic_template_expand line 64.
Edit: it also worked as expected when updating from an existing roundcubemail installation.
Thanks for testing
