SOGO webpage error
Sorry for the late reply!
But simply awesome weather and festival !!
In the sogo.log do is nothing, which is empty.
The only clue as I said is if you journalctl -xe calls.
greetings
Gerald
# **systemctl status sogod.service**
_ sogod.service - SOGo is a groupware server_
_   Loaded: loaded (/usr/lib/systemd/system/sogod.service; enabled; vendor preset: disabled)_
_   Active: failed (Result: timeout) since Sun 2016-09-11 12:17:03 CEST; 4min 48s ago_
_  Process: 29762 ExecStart=/usr/sbin/sogod -WOWorkersCount ${PREFORK} -WOPidFile /var/run/sogo/sogo.pid -WOLogFile /var/log/sogo/sogo.log (code=killed, signal=TERM)_
_Sep 11 12:15:33 ns7b.daheim.lan systemd[1]: Starting SOGo is a groupware server..._
_Sep 11 12:17:03 ns7b.daheim.lan systemd[1]: sogod.service start operation timed out. Terminating._
_Sep 11 12:17:03 ns7b.daheim.lan systemd[1]: Failed to start SOGo is a groupware server._
_Sep 11 12:17:03 ns7b.daheim.lan systemd[1]: Unit sogod.service entered failed state._
_Sep 11 12:17:03 ns7b.daheim.lan systemd[1]: sogod.service failed._
_[root@ns7b sysconfig]#_
WebTop 4 is quite old. Somewhere I read that they are working on wobtop 5, but I donā€™t know when it will be available. And If I will use WebTop4, if I will be able upgrade to 5 without data loss, or with complicated installation.
Take a look at this topic:
This is topic what I mean :smiley:
This fixed it for me
Thanks @Jeroen_Visser for your feedback, I appreciate it!:wave:
