Good work!
Is not the first time when are issues regarding local settings (regional language).
And not only with SOGo.
Because of that, I always use English.
@Miko10, if it is working you can undo the changes we have made in httpd.conf and ssl.conf (I wrongly said they wont be kept after a reboot, which is not true).
Note that the future maintenance of SOGo within NethServer is not clear.
I read about some problems with developers, but SOGO is still open source alternative for exchange. Hope it will stay in NS.
I would gladly update the rpms on NethForge.
Does anyone knows an alternative repository for compiled rpms?
Great shot!
Does anyone want to try the copr repo?
These commands should be enough:
wget https://copr.fedorainfracloud.org/coprs/jaile/sogo/repo/epel-7/jaile-sogo-epel-7.repo
yum install sogo
Hi, tried in VmWare, still problem with language. And sogo is not connected with NS LDAP by default.
So I also have problems with Sogo.
For me Sogo is not set in the Apache webserver area.
Here the issue with Curl:
# curl -kvIL https://192.168.1.98/SOGo/
* About to connect() to 192.168.1.98 port 443 (#0)
* Trying 192.168.1.98…
* Connected to 192.168.1.98 (192.168.1.98) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* skipping SSL peer certificate verification
* SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
* Server certificate:
* subject: L=Hometown,C=–,E=root@ns7b.daheim.lan,OU=Main,ST=SomeState,O=Example Org,CN=NethServer
* start date: Aug 30 17:28:29 2016 GMT
* expire date: Aug 28 17:28:29 2026 GMT
* common name: NethServer
* issuer: L=Hometown,C=–,E=root@ns7b.daheim.lan,OU=Main,ST=SomeState,O=Example Org,CN=NethServer
> HEAD /SOGo/ HTTP/1.1
> User-Agent: curl/7.29.0
> Host: 192.168.1.98
> Accept: /
_> _
< HTTP/1.1 404 Not Found
< Date: Sat, 03 Sep 2016 19:33:24 GMT
< Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.1e-fips PHP/5.4.16
< Content-Type: text/html; charset=iso-8859-1
_< _
* Connection #0 to host 192.168.1.98 left intact
maybe there is a simple possibility that the directories are set up.
In the installation I get the following message:
Is this ok [y/d/N]: y
Downloading packages:
_sogo-3.0.2-1.el7.centos.x86_64.rpm | 14 MB 00:00:03 _
Running transaction check
Running transaction test
Transaction test succeeded
Running transaction
_ Installing : sogo-3.0.2-1.el7.centos.x86_64 1/1 _
warning: %post(sogo-3.0.2-1.el7.centos.x86_64) scriptlet failed, exit status 1
Non-fatal POSTIN scriptlet failure in rpm package sogo-3.0.2-1.el7.centos.x86_64
_ Verifying : sogo-3.0.2-1.el7.centos.x86_64 1/1 _
Installed:
_ sogo.x86_64 0:3.0.2-1.el7.centos _
Complete!
[root@ns7b ~]#
greetings
Gerald
Hi again
Today I have installed updates and sogo login page again not working.
Does anybody think about alternative? Horde for example?
@gerald_FS, @Miko10: IMO the problem is due to a recent update of nethserver-httpd or virtualhost in the beta2 release.
@giacomo, any hint?
I guess so.
You could try with this (not tested):
rm -f /etc/httpd/conf.d/SOGo.conf
yum reinstall sogo
systemctl restart httpd
Try webtop 4
I had same problem in a fresh install ns7 beta 2 and it solve this for me.
Great!
For another language is solution:
yum reinstall sogo
systemct restart httpd
sed -i “s/}/ NSAMPMDesignation = (AM, PM);\n}/” /usr/lib64/GNUstep/SOGo/MainUI.SOGo/Resources/{Icelandic,NorwegianBokmal,NorwegianNynorsk,Slovak,Swedish}.lproj/Locale
Thanks.
Probably my last contribution to SOGo … but for the SOGo lovers, you can have an updated relase from Jaile repos:
cd /etc/yum.repos.d
yum install nethserver-sogo
yum reinstall sogo
Thanks allot. I’ve had the same problem and it works fine now.
mmm, I have done according to the statement, unfortunately comes at the start of the application the following message:
-- The start-up result is done.
Sep 08 19:27:47 ns7b.daheim.lan sssd_be[891]: GSSAPI client step 1
Sep 08 19:27:47 ns7b.daheim.lan sssd_be[891]: GSSAPI client step 2
Sep 08 19:28:34 ns7b.daheim.lan clamd[1201]: SelfCheck: Database status OK.
Sep 08 19:29:31 ns7b.daheim.lan polkitd[2022]: Registered Authentication Agent for unix-process:10543:8682310 (system bus name :1.183 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationA
Sep 08 19:29:31 ns7b.daheim.lan systemd[1]: Starting SOGo is a groupware server…
– Subject: Unit sogod.service has begun start-up
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
_-- _
– Unit sogod.service has begun starting up.
Sep 08 19:31:01 ns7b.daheim.lan systemd[1]: sogod.service start operation timed out. Terminating.
Sep 08 19:31:01 ns7b.daheim.lan systemd[1]: Failed to start SOGo is a groupware server.
– Subject: Unit sogod.service has failed
_-- _
– Unit sogod.service has failed.
_-- _
– The result is failed.
Sep 08 19:31:01 ns7b.daheim.lan systemd[1]: Unit sogod.service entered failed state.
Sep 08 19:31:01 ns7b.daheim.lan systemd[1]: sogod.service failed.
_Sep 08 19:31:01 ns7b.daheim.lan polkitd[2022]: Unregistered Authentication Agent for unix-process:10543:8682310 (system bus name :1.183, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from _
I do not know what to do yet, unfortunately WebTop is no alternative.
I need namely a German surface, and definitely a functioning synchronize to Android and Outlook.
greetings!
Hi Gerald,
Sogo provides only an activesync interface for outlook 2013 and 2016. Older versions only work with openchange, but this is not integrated in sogo and nethserver.
Before I changed to nethserver I’ve tried Zentyal with openchange, but it dosn’t work for me and nobody could support me, so I changed to nethserver.
Can you please search for any errors in /var/log/sogo.log
