SOGo 3.2.4 Packages needs testing
took a while,
Done in nethforge testing, version 1.6.1-1.14.g6835f7b.
Great work!
Updated 3.0.2 to 3.2.4 on a ns7-rc3 vm without problems. Authentication on local AD still works.
Will play a bit with it and report if any issue appears. Thanks for your work again Mark.
Hope you’re doiing well with your new job. :+1:
Still in testing? Looks stable to me, I’d like to move it on the update channel, what’s missing?
I just istalled a new NS7RC4 and installed the SOGo-Package from Softwarecenter and than updated to 3.2.4. The authentication issue still exists. I had to change the bindDN = "....." lines with the 2nd \ to get authentication agains nsdc working. And if I do a expand-template /etc/sogo/sogo.conf I have to do it again. So there is something still to do I think.
no, the version to solve the authentication comes from nethserver-testing, so you cannot use the software center
yum install nethserver-sogo --enablerepo=nethserver-testing
should do the trick
Mark seems away for a while.
If needed, I can pull and merge Mark modification to SOGo packages and release everything in NethForge.
I would take this way to avoid further SOGo discussions on something already fixed
Done.
I just released the following packages in NethForge (stable):
nethserver-sogo-1.6.2-1.ns7.src.rpm
  • First release for NS 7.3
nethserver-sogo-1.6.2-1.ns7.noarch.rpm
sogo-activesync-3.2.4-1.ns7.x86_64.rpm
  • refactor for maock build
sope49-debuginfo-4.9-20161202_324.ns7.x86_64.rpm
  • refactor for mock build
sope49-gdl1-mysql-4.9-20161202_324.ns7.x86_64.rpm
sope49-sbjson-2.3.1-20161202_324.ns7.x86_64.rpm
sope49-xml-4.9-20161202_324.ns7.x86_64.rpm
sope49-mime-4.9-20161202_324.ns7.x86_64.rpm
sope49-gdl1-contentstore-3.2.4-1.ns7.x86_64.rpm
sope49-gdl1-contentstore-devel-3.2.4-1.ns7.x86_64.rpm
sope49-appserver-4.9-20161202_324.ns7.x86_64.rpm
sope49-cards-3.2.4-1.ns7.x86_64.rpm
sogo-tool-3.2.4-1.ns7.x86_64.rpm
sope49-gdl1-4.9-20161202_324.ns7.x86_64.rpm
sope49-core-4.9-20161202_324.ns7.x86_64.rpm
sogo-debuginfo-3.2.4-1.ns7.x86_64.rpm
sope49-ldap-4.9-20161202_324.ns7.x86_64.rpm
sogo-3.2.4-1.ns7.x86_64.rpm
Sorry to ask again, but nethserver-testing or nethforge-testing? I got my upgrade from nethforge-testing. Are there sogo-packages in both repos?
Typo
nethforge-testing of course like you said
