Simplify DC management
Everybody knows that managing the Samba 4 DC is still a little bit tricky and prone to error.
After gathering your feedback, we came up with this list of things to improve:
  • stronger validator for IP address of the container
  • remove the “Create bridge” option and inform the user that the bridge will be automatically created
  • install bind-utils and ntp server inside the container
  • procedure to update the container
  • procedure to remove the whole DC (later)
  • simple procedure to reset the container
Regarding the “procedure to reset the container”, do you think that we need to add a button inside the web interface? Or is better to not add such dangerous feature inside the UI?
Vote!
  • Give me that damn button!
  • “With great powers comes great responsibility” - leave the power only to bash wizards
0 voters
This deserves a separate feature!
We have also in TODO list:
  • changing the nsdc IP address
  • set nsdc as additional domain controller
what do you mean presicely ?
By the way, it is a great new such improvements
This one: http://docs.nethserver.org/projects/nethserver-devel/en/v7/nethserver-dc.html#factory-reset
Davide already has some stub code for converting it in an event.
I think an event would be better than a button, especially because you don’t need it very often. At least I hope so. :smile:
