io con l’inglese sono abbastanza una frana quindi
provo a postare in italiano anche perche ho visto
dei filmati in italiano e ho da chiedere un po di cose
se possibile.
Grazie
se possibile.
Grazie
Hi @sbaragnus
Most of all are from Italy but we have choiced to use only english for this community.
Try to use Google translator, I use it very often when I have to write a post or translate a post that I can’t understand.
First times will be hard but I’m sure that post after post you will improve your english.
Please, if you have a question about NethServer try to write it in Italian then translate it and post.
Don’t worry!
Coraggio
I think that we still have the Italian forum on google:
https://groups.google.com/forum/#!forum/nethserver-it
Or is it closed?
thank you
try to use google
I wanted to ask first netserver is complete
type cpanel or plesk or is something different ?
Good start @sbaragnus
I know cpanel and plesk tools but I usually find them to manage common task for Web host/hosting.
NethServer is more oriented to manage shared folders, email accounts, firewall, proxy Web and other services useful for small and midsize businesses.
Hope to have understood correctly your question.
therefore does not have a specific tool for
apache and configuring vhost
in its web interface
but is specialized for samba postfix
firewall.
Not that I know.
Exactly and many other features very userful inside a small and midsize business.
There are shared folders, that can be configured as virtualhosts. See Virtualhost field in the web access tab in Shared folders.
So @filippo_carletti if I have a shared folder called ZULU I could configure a virtualhost such as http://nethserver.example.org/zulu or even with a different name?
Is it right?
Right @sitz. You can even have something like http://blog.example.org. Try it, it’s easier to configure than to explain.
