stephdl
(Stéphane de Labrusse)
May 26, 2017, 8:47pm
1
nethserver V7
Module nethserver-virtualhosts
Playing with the module nethserver-virtualhosts, I saw that you can set the same domain name to different virtualhosts. You do not have a validator to check if the FQDN is not already attributed to a virtualhost.
I mean about that
Virtual host names (FQDN)
The list of Fully Qualified Domain Names that are associated to the virtual host. Values must be separated with a "," (comma).
davidep
(Davide Principi)
May 27, 2017, 8:31am
2
I think somebody should file a bug about this
stephdl
May 28, 2017, 7:22am
3
davidep
(Davide Principi)
June 1, 2017, 2:51pm
4
A fix is ready for testing!
yum --enablerepo=nethserver-testing update nethserver-virtualhosts
stephdl
June 1, 2017, 5:41pm
5
I was thinking how to solve this bug, nice code…not tested yet…a bit busy at work
stephdl
June 5, 2017, 8:51pm
6
what is wrong ?
[root@NS7DEV2 ~]# yum --enablerepo=nethserver-testing update nethserver-virtualhosts
stephdl | 2.9 kB 00:00:00
* base: mirror.in2p3.fr
* epel: mirrors.ircam.fr
* extras: miroir.univ-paris13.fr
* nethforge: mirror1.nethserver.org
* nethserver-base: mirror1.nethserver.org
* nethserver-updates: mirror1.nethserver.org
* updates: mirror.in2p3.fr
No packages marked for update
[root@NS7DEV2 ~]# rpm -qa nethserver-virtualhosts
nethserver-virtualhosts-1.0.2-1.ns7.noarch
I cannot find your testing version
stephdl
June 5, 2017, 9:36pm
7
yum clean all --enablerepo=*
then the rpm is available
stephdl
June 5, 2017, 9:48pm
8
tested nethserver-virtualhosts-1.0.3-1.3.g8c19de1.ns7.noarch
I can see that a virtualhost is created by default, I did not understand what it means
[root@NS7DEV2 ~]# db vhosts show
default=vhost
Description=Default virtual host
FtpPassword=
FtpStatus=disabled
I can see that now a message is displayed when you try to share the same domain name between vhosts.
I saw also that the key name of the vhost is not tested, you can reuse the same key name.
giacomo
(Giacomo Sanchietti)
June 12, 2017, 7:37am
9
The fix has been released.
I also noticed the same thing, but this is a different issue. Honestly I didn’t want to open another issue for the web interface
