sharpec
(EnzoC)
May 21, 2017, 10:29am
1
NethServer Version: NethServer release 7.3.1611 (Final)
Module: Samba
Hello to everyone, I know it’s Sunday, but I’m at work and I thought I was disturbing you
After more year i finally ready for migration of zentyal file server on nethserver 7.3
zentyal name SRV
nethserver name SAMBA
on SAMBA I have created domain named XXX.it
when try to connect on \\samba from my pc, login don’t work
when try to connect on \\samba.XXX.it, login work
in my Windows file hosts, i have insert custom entry (only for test now, official switch is tomorrow morning)
192.168.1.241 srv
when try to connect on \\srv from my pc, login don’t work
More users in this year has work with Solidworks, this create big file with link to small file
\\srv\dwg\part1.sld
\\srv\dwg\part2.sld
etc…
without this link, file is inconsistent
Can i force login to an alias name on my DC Samba?
davidep
(Davide Principi)
May 21, 2017, 10:45am
2
Is your PC a win professional or home ed. version? Did it join the domain?
What is the DNS resolver config on your PC? Does it add XXX.it suffix?
ipconfig /all
sharpec
(EnzoC)
May 21, 2017, 10:58am
3
C:\Users\administrator.XXX>ipconfig /all
Configurazione IP di Windows
Nome host . . . . . . . . . . . . . . : admin-pc
Suffisso DNS primario . . . . . . . . : XXX.it
Tipo nodo . . . . . . . . . . . . . . : Ibrido
Routing IP abilitato. . . . . . . . . : No
Proxy WINS abilitato . . . . . . . . : No
Elenco di ricerca suffissi DNS. . . . : XXX.it
Scheda Ethernet Connessione alla rete locale (LAN):
Suffisso DNS specifico per connessione: XXX.it
Descrizione . . . . . . . . . . . . . : Scheda desktop Intel(R) PRO/1000 MT
Indirizzo fisico. . . . . . . . . . . :
DHCP abilitato. . . . . . . . . . . . : Sì
Configurazione automatica abilitata : Sì
Indirizzo IPv6 locale rispetto al collegamento . : (Preferenziale)
Indirizzo IPv4. . . . . . . . . . . . : 192.168.1.174(Preferenziale)
Subnet mask . . . . . . . . . . . . . : 255.255.255.0
Lease ottenuto. . . . . . . . . . . . : domenica 21 maggio 2017 12:48:04
Scadenza lease . . . . . . . . . . . : lunedì 22 maggio 2017 12:48:09
Gateway predefinito . . . . . . . . . : 192.168.1.254
Server DHCP . . . . . . . . . . . . . : 192.168.1.254
IAID DHCPv6 . . . . . . . . . . . : 235405351
DUID Client DHCPv6. . . . . . . . : 00-01-00-01-1E-49-07-A3-08-00-27-A5-AF-94
Server DNS . . . . . . . . . . . . . : 192.168.1.2 <---**NS-DC INTERFACE**
192.168.1.254
Server WINS primario . . . . . . . . : 192.168.1.2
NetBIOS su TCP/IP . . . . . . . . . . : Attivato
i have joined 3 machine at this time, al Pro version
My pc is a Win 10 home
But now i have try from a virtual machine win 7 pro, joined to domain, with worked admin tools.
same trick of hosts file, Login to SRV failed
i have try both enzo@xxx.it and xxx\enzo
load…load…load…
davidep
(Davide Principi)
May 21, 2017, 1:08pm
4
Is srv zentyal down? Is nsdc updated to samba 4.6?
Please try from your PC and paste the output of
ping srv
ping samba
Is the dhcp server NS? Did you set any advanced parameter (like wins) in dhcp?
To add an alias name (both DNS and NetBIOS)
remove the client host “trick”
update nsdc to 4.6
in nethserver DNS page add a server alias: srv
in nethserver DHCP page remove any WINS setting
reboot your clients to get a new dhcp lease
at nethserver console set a NetBIOS alias SRV
yum install nethserver-samba
config setprop smb NetbiosAliasList SRV
signal-event nethserver-samba-update
Please check /var/log/messages for any error when clients connect. Also per-client log under /var/log/samba/
sharpec
(EnzoC)
May 21, 2017, 2:54pm
5
now yes, renamed in srv2, samba service disable, firewall drop samba packet
DHCP server and SAMBA are 2 different machine, i have removed ns-dc ip from wins parameter
ok
davidep:
update nsdc to 4.6
updated from Configuration → Account Provider[quote=“davidep, post:4, topic:6865”]
[/quote]
srv.xxx.it added
done[quote=“davidep, post:4, topic:6865”]
[/quote]
in messagges i have many
May 21 16:42:01 samba systemd-machined: Got message type=signal sender=:1.81454 destination=n/a object=/org/freedesktop/systemd1/unit/httpd_2eservice interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=1417501 reply_cookie=0 error=n/a
May 21 16:42:01 samba systemd-machined: Got message type=signal sender=:1.81454 destination=n/a object=/org/freedesktop/systemd1/unit/httpd_2eservice interface=org.freedesktop.DBus.Properties member=PropertiesChanged cookie=1417502 reply_cookie=0 error=n/a
Per-client log is all empty 0byte
ll /var/log/samba/
total 20
drwx------ 4 root root 28 Nov 5 2016 cores
-rw-r--r-- 1 root root 0 Nov 5 2016 log.
-rw-r--r-- 1 root root 0 May 21 14:34 log.192.168.10.187
-rw-r--r-- 1 root root 0 Mar 30 13:43 log.192.168.1.11
-rw-r--r-- 1 root root 0 Nov 5 2016 log.192.168.1.120
-rw-r--r-- 1 root root 0 Feb 3 10:06 log.7-virt
-rw-r--r-- 1 root root 0 Apr 5 12:17 log.admin-pc
-rw-r--r-- 1 root root 0 Dec 22 09:43 log.amministra-pc
sharpec
(EnzoC)
May 21, 2017, 5:55pm
6
from ubuntu machine
smbclient //srv/officina -Uenzo@xxx.it
Enter enzo@xxx.it’s password:
Domain=[xxx] OS=[Windows 6.1] Server=[Samba 4.4.4]
tree connect failed: NT_STATUS_ACCESS_DENIED
yum info nethserver-dc
Loaded plugins: changelog, fastestmirror, nethserver_events, ovl
* base: mirror.euserv.net
* epel: fr2.rpmfind.net
* extras: wftp.tu-chemnitz.de
* nethforge: mirror.nethserver.org
* nethserver-base: mirror.nethserver.org
* nethserver-updates: mirror.nethserver.org
* updates: ftp.uni-bayreuth.de
Installed Packages
Arch : x86_64
Version : 1.2.1
Release : 1.ns7
Repo : installed
From repo : nethserver-updates
Summary : NethServer Domain Controller configuration
URL : http://github.com/NethServer/nethserver-dc
License : GPLv3+
Description : NethServer Samba 4 Domain Controller configuration
davidep
(Davide Principi)
May 21, 2017, 6:10pm
7
File system permissions?
ls -l /var/lib/nethserver/ibay
sharpec
(EnzoC)
May 21, 2017, 6:15pm
8
i think are correct
> total 144
> drwxrwsr-x 10 administrator@xxx.it domain admins@xxx.it 4096 May 18 10:18 aggi
> drwxrws---+ 24 administrator@xxx.it amministrazione@xxx.it 4096 May 8 14:54 amministrazione
> drwxrwsr-x+ 37 administrator@xxx.it domain users@xxx.it 4096 Mar 10 12:27 apps
on folder with guest read access, no problem,
on SAMBA login work, failed only on alias SRV, and log is empty.
Permission on log folder is correct root:root?
audit.log / smbaudit.log / log.smb …any entry with error or warning
Strange that samba does not log, he likes it so much
sharpec
(EnzoC)
May 21, 2017, 6:58pm
9
on a new vm joined to domain,
after reboot and login as admin@xxx.it
surf to \\samba
(real name) is direct, without password and show folder admin@xxx.it
surf to \\srv
(alias name), “error, user or password unknown”
sorry @davidep for this bad sunday
only possible solution is factory default dc?
sharpec
(EnzoC)
May 21, 2017, 7:26pm
10
in /etc/krb5.keytab
SRV is not present…No correlation?
i found this https://pagure.io/SSSD/sssd/issue/3228
What can happen if I change Fully qualified domain name
self-destruction??
davidep
(Davide Principi)
May 21, 2017, 8:09pm
11
Yes
Surely yes, however I didn’t mention kerberos because you have also win home edition. If you want to access a share from a domain workstation you need to add a SPN with the required host alias to the server keytab file.
I did it once with (kinda)
net ads keytab add NEWSPN
It’s not a solution! Please do not do it!!
Very interesting link. One thing I don’t understand: why fallback to NTLM (v2?) does not work/happen.
Try to increase smb log level:
smbcontrol smbd debug 1
We need a log clue to understand…
sharpec
(EnzoC)
May 21, 2017, 8:20pm
12
Sorry I had to explain better.
Tomorrow morning 20 colleagues arrive, who will have to access the server.
I am one of the few with home edition.
Tomorrow I will have most clients win 7 pro out of domain
I wanted try to keep the name of the server unchanged
This is why I have some delphi programs pointing to SRV name, or excel file links, or solidworks drawings
davidep
(Davide Principi)
May 21, 2017, 8:31pm
13
For them you have to add the missing SPNs to the keytab!
As the link above explains the command should be like
net ads keytab add cifs/srv@XXX.IT cifs/srv.xxx.it@XXX.IT host/srv@XXX.IT host/srv.xxx.it@XXX.IT
sharpec
(EnzoC)
May 21, 2017, 8:50pm
14
THANKS @davidep
i have try, but none…
before call \srv in windows client joined KLIST was empty
after klist contained
Client: admin @ XXX.IT
Server: cifs/samba.xxx.it @ XXX.IT
May fail for this mismath?
another mismatch is present between Status -> Domain Account
and net ads keytab list
only in the second are present [quote=“davidep, post:13, topic:6865”]
[/quote]
if i do net ads keytab flush
and re-add all items…but for first SRV?
davidep
(Davide Principi)
May 21, 2017, 9:00pm
15
IIRC the keytab entries order is not important.
Did you add the srv-based entries to keytab? Maybe a smbd restart is required.
Also the DNS is important: if the smbd restart does not fix the issue, I suspect from your KLIST output the srv name is canonicalized to samba with a reverse-dns call. This is a fallback measure though…
Please paste the output of
klist -k /etc/krb5.keytab
sharpec
(EnzoC)
May 21, 2017, 9:10pm
16
[root@samba officina]# klist -k /etc/krb5.keytab
Keytab name: FILE:/etc/krb5.keytab
KVNO Principal
1 host/samba.xxxxx.it@XXXXX.IT
1 host/SAMBA@XXXXX.IT
1 SAMBA$@XXXXX.IT
1 SAMBA$@XXXXX.IT
1 SAMBA$@XXXXX.IT
1 SAMBA$@XXXXX.IT
1 SAMBA$@XXXXX.IT
1 smtp/samba.xxxxx.it@XXXXX.IT
1 smtp/SAMBA@XXXXX.IT
1 pop/samba.xxxxx.it@XXXXX.IT
1 pop/SAMBA@XXXXX.IT
1 imap/samba.xxxxx.it@XXXXX.IT
1 imap/SAMBA@XXXXX.IT
1 cifs/samba.xxxxx.it@XXXXX.IT
1 cifs/SAMBA@XXXXX.IT
1 srv/samba.xxxxx.it@XXXXX.IT
1 srv/SAMBA@XXXXX.IT
1 cifs/srv@xxxxx.IT
1 cifs/srv@xxxxx.IT
1 cifs/srv@xxxxx.IT
1 cifs/srv@xxxxx.IT
1 cifs/srv@xxxxx.IT
1 cifs/srv.xxxxx.it@xxxxx.IT
1 host/srv@xxxxx.IT
1 host/srv@xxxxx.IT
1 host/srv@xxxxx.IT
1 host/srv@xxxxx.IT
1 host/srv@xxxxx.IT
1 host/srv.xxxxx.it@xxxxx.IT
1 SRV.XXXXX.IT/samba.xxxxx.it@XXXXX.IT
1 SRV.XXXXX.IT/SAMBA@XXXXX.IT
davidep
(Davide Principi)
May 21, 2017, 9:23pm
17
OK I don’t know if case is relevant here, but I see a couple of entries are still missing (comparing to samba ones)
cifs/SRV@XXXXX.it
host/SRV@XXXXX.it
This should not be needed, but does not harm:
SRV$@XXXXX.it
Finally
systemctl restart smb
sharpec
(EnzoC)
May 21, 2017, 9:37pm
18
with
davidep:
SRV$@XXXXX.it
insert SRVXXXXX@XXXXX.IT
sorry 'SRV$'@XXXX.IT
work but don’t solve my stupid problem
davidep
(Davide Principi)
May 23, 2017, 3:50pm
19
Hi @sharpec , I’ve tried to reproduce the scenario on a VM file server, joined to a remote nsdc. What I did is
systemctl stop smb nmb
It works from both domain workstation (kerberos, win10) and smbclient. No DNS alias was required, i guess because in LAN netbios name resolution works here.
The klist
command on win10 reports an empty cache, thus it confirms NTLM protocols are used as fallback.
Did you manage to solve your issue?
sharpec
(EnzoC)
May 23, 2017, 7:30pm
20
I try tomorrow, Tonight I go to bed soon
Thanks for your help and yours efforts!
EDIT: Ok I tried, but it does not work
I do not want to make you spend more time, I’ve migrated old name to the new one
Thank you very much
