RSAT and Roaming Profiles NS7
NethServer 7.3.1611: ** 2 Win 7 pro **
everything on Proxmox 4
Hi everybody,
excuse my english.
I try to make an AD : srv.dom.local with ad.dom.local
it looks good
install "file server"
it looks good (users and group)
PC can join and connect AD : ok
I see there is no roaming profiles,
so I want to follow : Roaming profiles in ns7 Active Directory
but I can’t connect my mmc or dsa.msc to my AD.
What I did :
  • install rsat tools on pc1
  • join the AD (DOMAIN = dom) with pc1
  • login pc1 with admin or administrator (witch one ?)
  • mmc : add “user and computers Active Directory” module
  • error : les informations de noms sont introuvables pour la raison suivante : serveur n’est pas opérationnel
    (server not operationnal)
Did I something wrong ?
Thanks a lot
DS
What I did now : i
log PC 1 with “admin” to connect AD
I add windows fonctionnality now instead on PC1 out of the domaine.
and it’s work
hope it helps.
… and now roaming profiles :wink:
bye
DS
I’m not a RSAT tools expert so I need to call some experts for help
@uliversal @Mattallyc @saitobenkei @des
Did you take a look at old discussions?
Good to know. Can you help us with a video or a set of screenshots so we can guide our members on this path?
…I read a lot of discussion, but i’m french and I surely forget some words.
I’ll will see for screenshots.
the server name is :slight_smile:
NSDC.SRV and not SRV
I did not use earlier Roaming Profiles (i don’t had to) but i will try to test it and let you know if it works
it does !
according to http://community.nethserver.org/clicks/track?url=%2F%2Fcommunity.nethserver.org%2Ft%2Froaming-profiles-in-ns7-active-directory%2F5259%2F13&post_id=43753&topic_id=6969
thanks to @uliversal
Great news! After my comeback from holidays i will finally start setting things up at work!
