I just installed and setup Nethserver. So far everything worked like a charm. Thanks everybody for this wonderful piece of software.
I´m wondering what ist the best way to add plugins to roundcubemail. I´m not familiar with the signal event system in nethserver. So can I just use composer like suggested on the round cube website?
Where do I have to put the config.inc.php for every plugin? Is there a special directory for the config-files?
roundcubemail 1.2 can be installed from remi repository, I bet that soon we will have it in epel. Be aware to not upgrade your php version if you try the update
