Reports -> Samba audit: no records
In /usr/bin/, there is only “smbauditdbupdate.pl”
The Reload link is using that option and logrotate is called through php system(sudo …)
The smbauditrotate.pl appears in the .spec file but is no longer present in NS7. I could be wrong but think it’s no longer needed.
Maybe it is just some sudoers/permissions issue.
I’m moving this to the bug section.
IT WORKS!
Thank you @giacomo!
YOU ARE THE MAN! :clap::clap::clap:
This is for speed: :trophy:
PS:
No “Edit” option!
Thank you @dnutan!
Interesting. Frankly… the samba audit gui is less useful to my eyes than just doing a control f with the browser in the log gui against smbaudit.log, but we don’t get smbaudit.log without installing samb-audit… idk.
If you need only a text log, you could use the full_audit module of Samba.
Just create a template custom like the one from samba-audit:
