Jim
June 11, 2017, 6:59pm
1
Hello,
When looking in Security Network services, I’ve got this:
As you can see there are the Avahi-deamon and the Netatalk services shown.
But in the Status Services menu… There aren’t !!!
If I remember in the NS 6 series… the two services was present… And able to be restarted here.
It’s look like a little bug here…
Jim
June 12, 2017, 12:40pm
2
I’m try to make Netatalk running properly, and I’m doing a test without Samba and without AD,
After deinstalling all in the Software Centre…
There’s another anomaly with the SMB service:
davidep
(Davide Principi)
June 16, 2017, 8:51am
5
Hi @Jim , how did you install netatalk in ns7?
About avahi-daemon: in a fresh install it is available on both pages (“Security > Network services” and “Status > Services”)
[root@vm8 vmail]# config show avahi-daemon
avahi-daemon=service
UDPPort=5353
access=private
status=enabled
Jim
June 16, 2017, 11:48am
6
[root@Microserver ~]# config show avahi-daemon
UDPPort=5353
access=green
status=enabled
I installed by the command line nethserver-avahi
I will forget: Thank you @discobot for your useful and successful service
