Error: sieve: before: line 21: unknown tagged argument ‘:copy’ for the redirect command (reported only once at first occurence)
Sep 13 14:55:13 posta dovecot: lda(assistenza@studiolegalereggianini.it): Error: sieve: before: validation failed
Sep 13 14:55:13 posta dovecot: lda(assistenza@studiolegalereggianini.it): Error: sieve: failed to compile script /var/lib/nethserver/sieve-scripts/before.sieve
probably miss something …
other questions: the file says not to edit it but to change the custom template, can you tell me where the template is to be permanently modified?
As always thank you!
The template I have edited at following location: \etc\e-smith\templates-custom\var\lib\nethserver\sieve-scripts\before.sieve
Inside this directory there is a file “10junkmail” which you can edit.
