Hi folks,
I have a standard installation of 2 versions: NethServer 6.9 and NethServer 7.3. These servers are used as local mailserver (intranet). Smarthost is used to send/ receive mails to/ from ISP’s mail server…
I have checked the box in Email-> Messages “Always send a copy (BCC)”. This works at NethServer 6.9 but doesn’t work with version 7.3. If I send a mail this will be CCed to mailcc@FQDN (my catchall mailbox/ user) and everything is fine. But if I send a mail to an external echo mailserver (via ISP’s mail server) the reply (echo mail) will be sent only to the senders postbox and not to the mailcc-Postbox.
Maybe this depends on Email alias domains or server alias? Is the character “-” (minus) allowed for domain names? My server name is “mail.proxyserver.de”. Additional I have set “company-place.de” as an alias.
Next I will try to proceed with an update process vom NethServer 6.9 to 7.3…
What can I do else for debug/ diagnostic or does anybody have an idea to check this behaviour?
Now I can send mails from “banane” to “kiwi” and I will get a copy to “mailcc”. So far so good.
Next I want to send mails to an external mailbox via an ISP mailserver. What do I have to do?
I have to configure:
a second Email Domain “xxx-erfurt.de” on NethServer according to the public mailbox domain
Smarthost function with correct data for sending mails to the ISP
POP3 connector with external mail account data to get mails from the ISP to NethServer
Is this right?
Please can anyone give me an advice? Can you replicate this behaviour?
Don’t hesitate to contact me!
Thanks for spending your time and best regards,
Mario!
…for test purposes I’ve put these lines into "/var/lib/nethserver/sieve-scripts/before-sieve/“
require [“copy”];
if true
redirect: copy "mailcc@proxyserver.de”;
Hi all,
I think I’ve done 1 step to the solution…
The sieve filter now makes a copy to "mailcc@proxyserver.de" but I get 4 duplicate messages from the echo mailserver to mailcc. How can I prevent this?
Hmm, I’ve unchecked Email-> Messages-> Always send a copy (Bcc)… and now I will receive only 1 message as a copy from "echo@tu-chemnitz.de" to "mailcc@proxyserver.de" (and of course to "banane@ifam-erfurt.de"). This is exactly the behaviour I would like to see.
Unfortunately in this case I won’t receive a copy of the mail I have sent from “banane” to the echo Server…
Hi Filipo,
I have added the line with stop;
from your advice, but the result is the same, no change at all (2 duplicate mails).
I am totally confused because I receive additional mails to ‘mailcc’ from sending “banane” -> “echo” after I had used the sieve filter…?
Does sieve filter work for outgoing and incoming mails?
Mario
I’ve seen there are some extensions for the sieve package, one of them is called ‘duplicate extension’. Whats about this, can I install/ use this extension? How can I install an extension?
Incoming only.
I have a customization to disable delivery of duplicated email.
It’s a small .tar.gz file I could send to your email address (if you can give it to me in a Private Message).
I am very satisfied with the help of your support, my problem is solved and everything works very well. The duplicate extension for Sieve filters does the job. A big compliment and many thanks for the great support!
Summary:
I wanted to use the Option “Configuration: Email-> Messages-> Always send a copy (Bcc)…” This already works for outgoing mails (postfix will do this, right?). For incoming mails you have to add a line with 'redirect: copy "<catchall-mailbox>";' into “/var/lib/nethserver/sieve-scripts/before-sieve/”.
And then it is usefull to install/ use the ‘Duplicate extension’ for Sieve filters to avoid duplicate mails.
The only thing I have to do is to create a custom template for sieve…
Finally I am very pleased to found NethServer Project and this community.
hello everyone, can i ask the exact syntax of the file? I do not function and I get this error:
Sep 13 13:40:02 mail dovecot: lda (assistenza@xxxxx.it): Error: sieve: before: line 21: expected end of command ‘;’ or the beginning of a compound block ‘{’, but found ':'
Sep 13 13:40:02 mail dovecot: lda (assistenza@xxxxx.it): Error: sieve: before: parse failed
Sep 13 13:40:02 mail dovecot: lda (assistenza@xxxxx.it): Error: failed to compile script /var/lib/nethserver/sieve-scripts/before.sieve
Sep 13 14:20:02 posta dovecot: lda(assistenza@xxxxx.it): Error: sieve: before: parse failed
Sep 13 14:20:02 posta dovecot: lda(assistenza@xxxxx.it): Error: sieve: failed to compile script /var/lib/nethserver/sieve-scripts/before.sieve
Hi luca,
in my first attempts to edit this sieve script I made the same mistake…
It is important that you type the semicolon without space after but with a space before!
… “header :contains”
… “file :create”
… “redirect :copy”…
Sure this will help you
Mario
