Phpmyadmin for NethServer
Maintainer
Stephane de Labrusse AKA @stephdl (stephdl [@] de-labrusse.fr )
Description
Implementation of phpMyAdmin for Nethserver, from the original ideas and works of all developers involved in “smeserver-phpmyadmin”: http://wiki.contribs.org/PHPMyAdmin.
Installation
nethserver-phpmyadmin is on NethForge repository which is not part of default NethServer installation. Read the instructions for installing NethForge repository.
After nethserver-nethforge-release has been installed proceed with:
yum install --enablerepo=nethforge nethserver-phpmyadmin
see default settings, please issue that command in a root terminal
config show phpmyadmin
phpmyadmin=configuration
access=private
adminaccess=enabled
multiaccess=disabled
You have two principal modes to log in phpmyadmin, all combinations are possible.
You can use adminaccess and multiaccess together or one instead the other.
Mode adminaccess
Access with admin/password (same as the password of server-manager) via:
https://yourdomain/phpmyadmin
In this mode you are in a single mode only, no other ways to delegate the DB management to other users.
In order to enable or disable :
config setprop phpmyadmin adminaccess enabled/disabled
signal-event nethserver-phpmyadmin-save
Mode multiaccess
In this mode you can delegate the DB management to other users by the user and the password of the database.
Furthermore this mode is more convenient since the authentication is made with cookies. You can easily close the session.
With the multiaccess mode, the admin account gets a new password which comes from ‘/etc/my.pwd’.
Once you retrieve it, you can change it in the phpmyadmin session for a password more easier to recall.
to retrieve the admin password :
cat /etc/my.pwd
You can access via:
https://yourdomain/phpmyadmin-multi 		if adminacces is enabled and multiaccess is enabled
https://yourdomain/phpmyadmin 			if adminacces is disabled and multiaccess is enabled
config setprop phpmyadmin multiaccess enabled/disabled
Restrict access (local network or internet)
You can set how the access to phmyadmin is allowed
public : all internet (can be dangerous)
private : only your local network
config setprop phpmyadmin access public/private
just installed…good work @stephdl !
hi now it has a Bug ,
after i run signal-event nethserver-phpmyadmin-save
i could not access to WebUi by user “admin”
@Nas You are trying to enter nethserver or phpmyadmin?
I try to login to phpmyadmin and webui, in template I found old DB parameter , maybe it does some harm :frowning:
Yellow Crowd;
wondering if I was alone in my ship!
actually the installation works pretty well
and from what I see, i’m in single admin access mode
when I tried to authentified myself nothing work
I’d tried with the user root or admin
with my common password working for the SSH and the WEBUI
and or Nethesis,1234 even with the one from /etc/my.pwd
but without success
it is normal, should I restart mysql into a rescue mode and reset the root mysql password ?
Thank!
Jonathan
So i’d just reset my admin password with the same password, and now my admin/root password works for phpmyadmin :wink:
I just tried by passing in multiuser mode and it work too
Great works @stephdl
Will phpmyadmin be included a module for NS7?
I have tried to install the current version of phpmyadmin (using the compressed source provided by the project site) and found that it requires PHP version 5.5.0 or above (NS7 RC2 has v5.4.16 installed).
Please check this:
http://wiki.nethserver.org/doku.php?id=phpmyadmin
A good walk-through provided by stephdl!
Hello,
I do not know 'if they are in the right place.
my question is:
if you change my ip to the server after there 'more access to the phpmyadmin
If ip reset returns available.
I’m not sure to fully understand your question, but phpmyadmin is alias based in apache, so it never looks after the server IP.
to reach phpmyadmin
https://SERVER_IP/phpmyadmin
¿It uses the trusted networks for config the Apache?, if not please tell me how to write the template to allow OpenVPN network for phpmyadmin.
openvpn should be part of the local network, at least for openvpn bridge
I made the probe, it´s only to declare the trusted network and signal-event nethserver-phpmyadmin-save makes the right template.
This is pretty good. Salud2
You even don’t need to launch the event netheserver-phpmyadmin-save, the event trusted-networks-modify when you save the new local network in the panel should be enough, but I missedd to restart the http service
new version is coming
done
