Hello people, I am aware that this is not officially supported, but I wondered if someone could help me out here. I am trying to set the max_input_vars for php71 to 2000, instead of the default 1000.
I do this by issueing the following command:
config setprop php71 max_input_vars 2000
signal-event nethserver-php-update
When I did this for max_execution_time, it worked fine.
When I do a config getprop php71 max_input_vars, I get 2000. When I reload my Typo3 install package, it still complains about this value beig 1000.
I rebooted the system just to make sure that I was nog missing something ovious, without improvement.
To make extra sure I issued the config setptop command for php, php70 and php71 … they all come back with 2000 when I getptop them …
Any clue where I should be looking to diagnose this ?
Sometimes I get tired of my own sloppy reading. Thanks for helping me see the light.
I created the correct folder structure under /etc/e-smith/templates-custom/ and added the max_input_vars = 2000 in the file 21ResourceLimits. Used signal-event and I am a happy camper now.
Up till now I equated one with the other, which is, in hindsight, just stupid. Thanks a lot.
Because Typo3 lists it as a recommendation in the pre-setup check. It can continue without it being adjusted, but I see no reason to. So this value had to change
Daim, you guys are solid gold. I work at a software company where I just skip the manual, as it is incomplete anyway. You guys even have little stuff like this documented …
RTFM could have saved me a nice chunk of time here :o Thanks again!
Hi everybody,
I have got almost the same problem on my VPS hosting Prestashop.
Using all information from this post i have solved the same problem
thanks @planet_jeroen and @stephdl
I assume that you installed my rpm nethserver-php-scl and you have created a virtualhost called wordpress, then you will find all the configuration at /etc/opt/remi/php73/php-fpm.d/php-fpm.wordpress.conf
I propose you create a file /etc/opt/remi/php73/php-fpm.d/z_php-fpm.wordpress.conf
