Performance low in sogo-webfrontend
Linux uses all the memory it owns…you just need to worry if you see the swap growns a lot
this is what your server is expected to do… it will use all the available RAM
there’s no topic here
as Stephdl said, you’d start worrying if/when you’ll see your swap increasing…
RAM is good to be used, all of it
