Partition schema for AD
Hello everybody,
I had a server which i indend to create AD, but there could be some MySQL/PostgreSQL and HTTP instances
Server configuration
  • drive 250GB - intended for “/”, “/boot”, “/tmp” and so on
  • RAID 4TB - for share folders, DB, and WWW
My question is how to do a proper partition for that server?
I have found that NethServer Samba AD stores folders at /var/lib/nethserver dir.
How about databases and www sites?
Thanks
Dominik
Hello Dominik!
This is an old request from me, this concept I have implemented and looks quite well :wink:
Hello Gerald,
Thank you for the info - i have also readed some NS docs, posts, faq’s and found that NS holds almost all configuration in /var/lib/nethserver.
Thank you for your help!
