In my company w7 users logged to domain only need access to departament/group shares. But NS6.8 mount also a home directory per user.
Trying to solve this i naively edit the smb.conf (commenting out the [homes] section) but a few minutes later it was overwritten.
This way i discover the NS template system. After some read of the dev manual i couldn’t figure how to make this change permanent.
Same problem was presented in this nethserver forum post but is long due orphaned.
There is a way to do that?
Finally got this. Permanent template for samba shares is located in
/etc/e-smith/templates-custom/etc/samba/smb.conf/70shares
Edited that file to looks like: (commenting out relevant lines)
; Deshabilitado en /etc/e-smith/templates/etc/samba/smb.conf/70shares
;[homes]
;comment = Home directories
;browseable = no
;writable = yes
;create mode = 0660
;force create mode = 0660
;directory mode = 0770
;force directory mode = 0770
;path = {$baseDir}/home/%S
Then run:
signal-event nethserver-samba-update
to update samba configuration
Your solution is good but partial. It works until nethserver-samba is updated.
To make the customization permanent, copy
to
Then edit it as you like.
This is documented here
THX Davide!
Please, fix your comment above and mark it as solution for future reference!
