giacomo
(Giacomo Sanchietti)
June 9, 2017, 1:54pm
21
Tested and it works.
But I have a much simpler solution (I hope): create an index.html file
If the user select the option âcreate a default index fileâ, we can execute something like this from vhost-create event:
echo "Welecome to www.test.org virtualhost" > /var/lib/nethserver/vhost/test/index.html
stephdl
(Stéphane de Labrusse)
June 9, 2017, 1:58pm
22
And what it could occur if the user removes the index.html
To developers⊠think that your softwares are used and your users are idiots
giacomo
June 12, 2017, 7:43am
23
Ok, Iâm fine with your solution: we can add this option to all virtual hosts as default.
Would you like to open a PR or we can add it to our junior job list?
stephdl
June 13, 2017, 7:48pm
24
I will try something. I have my build server broken, I need time to fix it.
giacomo
June 19, 2017, 12:52pm
25
In the meanwhile, also added to junior jobs to not loose the suggestion:
https://github.com/orgs/NethServer/projects/1#card-3412277
stephdl
June 19, 2017, 7:24pm
26
just thinking loudly, it could be time to get a lot more settings in the virtualhost
I mean
php settings
apache settings
user access by password
giacomo
June 20, 2017, 7:11am
27
Iâm open to any new improvement , but I didnât see so much interest on it. Or am I missing some request?
stephdl
June 20, 2017, 8:14am
28
I have started to work on the indexes option tonight. I will do a PR soon
When i spoke about more settings i think about nethserver-phpsettings, I think that I would remove the allowoveride option, and why not allow symlink if I need.
The user/group access will be interesting with mod dav
davidep
(Davide Principi)
June 20, 2017, 10:06am
29
Letâs split this topic and open a new #feature request!
How would you title the new topic?
stephdl
June 20, 2017, 4:18pm
31
giacomo
June 30, 2017, 7:45am
32
Sorry for the delay,
but finally we have it merged!
