No mega like but a bunch of hearts and thumbs up:
Thank for help. i have same issue in my installation and solve it.
well my fat fingers have played again, since the urbackup is enabled by default we donât need to call it by the command ââenablerepo=*****â
so it is not needed to change something, just do
wget http://download.opensuse.org/repositories/home:kot1grun/CentOS_6/home:kot1grun.repo -O /etc/yum.repos.d/urbackup.repo
yum install http://mirror.de-labrusse.fr/nethserver/nethserver-urbackup/nethserver-urbackup-0.0.1-1.ns6.sdl.noarch.rpm
hallo stephane, tried it and it works, but the /var/lib/urbackup dir must be done manually. is it supposed to be this way or do you want to give a standard dir? Maybe itâs an idea to install a standard dir and give users an advice about it or that they can choose any other directory. The advantage would be, that the standard user can install urbackup without using the console.
OupsâŠit is a bug
Itâs not a bug, it is a feature you claim
off-topic:
yum install http://mirror.de-labrusse.fr/nethserver/nethserver-urbackup/nethserver-urbackup-0.0.2-1.ns6.sdl.noarch.rpm
new version, /var/lib/urbackup is created automatically but you must set it manually in the setting tabs. I have asked to the urbackup community how I can push my specific settings directly after the installation⊠wait and see.
confirm that this works. I hope that the urbackup community is as helpfull as nethserver community!
Itâs seems so⊠The main dev is really reactive
Just a quick question: Is it possible to use uRbackup with a webdav volume on a remote system? Then it might be possible to use something like owncloud as a place to store the backups
Well Iâm not sure that a webdav file system is a good choice to store backups. NFS, SMB, FTP, local hard drive are often a good choice in term of reliability and speed.
In fact neither urbackup or backuppc give you this feature. Of course if Iâm wrong, please shout !
thnx stephdl for clearing that up. ItĆ not that I absolutely need webdav, but more an idea to make use of an owncloud solution.
Just whant to give a short feedback after some weeks of use.
Urbackup works stable and without any issue.
After some playing with settings, i found the right for me, so consumed diskspace isnât to high.
I have 12 clients on urbackup and all are working smooth.
The only thing I had to figure out was to delete the "server_indents.txt " and âsession_idents.txtâ in programmfolder, when a client lost his connection and didnât find it again. But that was because of tests with urbackup on a ns7a3-vm. So i like urbackup and will keep it for my clients.
Thanks again to @stephdl for your work.
Thanks for your feedback Iâd like to see urbackup in our NethForge soon, so everyone can use it and improve their NethServer installations. Iâm also thinking about a blog post on NethServer as Backup Station Machine
Hello everybody. From the UrBackupâs website itâs possible to download the new UrBackup 2.x version. I have tested it in a Centos 7 server. The new versionâs RPM packages arenât ready, so we can only install from sources. About the RPM packages, in this moment, the link is for UrBackup version 1.4.x.
I checked the compatibility between client 1.4.x and server 2.x and between client 2.x and server 1.4.x. Everything itâs working.
Thatâs a great news, what about 2.x? Any feature thatâs worth mentioning?
Any updates on urbackup for NS7?
on the roadmap
