Nethserver-phppgadmin needs testers
a rpm to manage your postgresql server
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-phppgadmin-0.0.1/nethserver-phppgadmin-0.0.1-1.ns7.sdl.noarch.rpm
then go to https://YOURIP/phppgadmin or use the button in the application panel of your Server-manager
the user : admin
the password : cat /var/lib/nethserver/secrets/pgadmin
once logged you can change it as you want by the phpPgAdmin application
you have some db
[root@NS7DEV6 ~]# config show phppgadmin
phppgadmin=configuration
    MemoryLimit=500M
    PostMaxSize=100M
    UploadMaxSize=100M
    access=private     # set to public for an external access
    status=enabled     #set to disabled to stop the service
for example :
config setprop phppgadmin access public
signal-event nethserver-phppgadmin-save
Of course, please report bugs and remarks
It could be extremely useful to manage Webtop database @lucag will defintely love it
Good job @stephdl :thumbsup:
I just successfully installed your rpm.
It all works great :ok_hand:
Thanks for your Christmas gift :christmas_tree::wink:
thank you so much :slight_smile:
NS6 version is cooked
released in my repository the documentation is at http://wiki.nethserver.org/doku.php?id=phppgadmin
Another great module :wink: thanks
