great!
added nethserver-devtools and nethserver-mock, installation went fine… keep us informed. tnx
I’m surprised too, thanks for starting this compelling topic! There are many amazing people around here
Just rebuilt my mock cache, all seems good so far.
http://mirror.framassa.org/nethpi/7/base/armhfp/repodata/repomd.xml: [Errno 14] HTTP Error 504 - Gateway Timeout
I’ll try to review mock.cfg in the weekend, I’d like to add it to the wiki page.
Next step: cross compilation. Anyone has experience in this matter?
yes server is down, i hope to check it in the afternoon sorry
@filippo_carletti can you try now? tnx
This is great!
Not on CentOS and the like. Centos has a cross compiler package, but i can’t figure out to build a tool chain.
If there is a mock.cfg to make nethserver-packages om arm, i’ll think a arm devel-setup will do. the packages are relativlie small. I was looking in to it bçause under some circumstances build dependancies can be met by the build-host (i.e you need this in your tool chain, x86 lib will do)
BTW i think they are done (re)building the hole epel repo; today the repodata showed up in the devel repo’s
That’s critical, we need epel packages for many modules.
Here’s my mock cfg. Put it in /etc/mock/ and set
mockcfg=nethserver-7-armhfp
/etc/mock/nethserver-7-armhfp.cfg
# NethServer 7 armhfp mock configuration
import string
distroversion = '7.2.1511'
releasever = distroversion.split('.')[0]
config_opts['target_arch'] = 'armhfp'
config_opts['legal_host_arches'] = ('armv7l')
config_opts['root'] = 'nethserver-%s-armhfp' % releasever
config_opts['chroot_setup_cmd'] = ('install', 'bash', 'util-linux-ng', 'rpm-build', 'gcc', 'gcc-c++', 'make', 'python', 'which')
config_opts['plugin_conf']['ccache_enable'] = False
config_opts['macros']['%url_prefix'] = 'http://github.com/NethServer'
config_opts['macros']['%vendor'] = 'NethServer'
config_opts['macros']['%dist'] = 'ns7'
# Substitute $releasever and $basearch:
config_opts['yum.conf'] = string.Template("""
[main]
cachedir=/var/cache/yum
debuglevel=1
logfile=/var/log/yum.log
reposdir=/dev/null
retries=20
obsoletes=1
gpgcheck=0
assumeyes=1
plugins=1
ui_repoid_vars=1
http_caching=none
[base]
name=CentOS-$releasever - Base
enablegroups=0
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os&infra=$infra
baseurl=http://mirror.centos.org/altarch/$releasever/os/$basearch/
gpgcheck=1
enabled=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-7
file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-SIG-AltArch-Arm32
#released updates
[updates]
name=CentOS-$releasever - Updates
enablegroups=0
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates&infra=$infra
baseurl=http://mirror.centos.org/altarch/$releasever/updates/$basearch/
gpgcheck=1
enabled=1
#additional packages that may be useful
[extras]
name=CentOS-$releasever - Extras
enablegroups=0
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras&infra=$infra
baseurl=http://mirror.centos.org/altarch/$releasever/extras/$basearch/
gpgcheck=1
enabled=1
#additional packages that extend functionality of existing packages
[centosplus]
name=CentOS-$releasever - Plus
enablegroups=0
#mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=centosplus&infra=$infra
baseurl=http://mirror.centos.org/altarch/$releasever/centosplus/$basearch/
gpgcheck=1
enabled=0
# nethserver-arm YUM repositories configuration
[nethserver-base]
name=NethServer $distroversion-arm base
#mirrorlist=http://mirrorlist.nethserver.org/
baseurl=http://mirror.framassa.org/nethpi/$releasever/base/$basearch
#gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethServer-$releasever
gpgcheck=0
enabled=1
enablegroups=1
[nethserver-updates]
name=NethServer $distroversion-arm updates
baseurl=http://mirror.framassa.org/nethpi/$releasever/updates/$basearch
gpgcheck=0
enabled=1
enablegroups=1
[nethserver-testing]
name=NethServer $distroversion-arm testing
baseurl=http://mirror.framassa.org/nethpi/$releasever/testing/$basearch
gpgcheck=0
enabled=0
enablegroups=0
[epel]
#Temporary placeholder for missing epel repositories
name=NethServer $distroversion-arm placeholder for epel
baseurl=http://mirror.framassa.org/nethpi/$releasever/ns-epel/$basearch
gpgcheck=0
enabled=1
enablegroups=0
#[epel]
#name=Extra Packages for Enterprise Linux $releasever - $basearch
##baseurl=http://download.fedoraproject.org/pub/epel/$releasever/$basearch
#mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-$releasever&arch=$basearch
#failovermethod=priority
#enabled=1
#gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-$releasever
""").substitute(distroversion=distroversion, releasever=releasever, basearch=config_opts['target_arch'], infra='stock')
If anyone interested, we can also try the build infrastructure from CentOS for arm64: http://cbs.centos.org/koji/hosts
Ran out of hardware to test this (monitoring install’s with munin)
Could not resist and bought a PI3, gone have a go soon
LOL me too yesterday… Also because tomorrow I must return the rpi2 i’m using for testing to my friend
@jackyes CentOS still uses the “noob” config.txt, under-clocking the rpi3 on 700 MHz.
Do you know moderate (stable) settings for clock/core/dram and the like?
@dz00te @giacomo hesitated long to get a RPI3 because an eye on this:
http://www.hardkernel.com/main/products/prdt_info.php?g_code=G145457216438
My pi3 stabile at 1300mhz, SDRAM freq 400 overvolt 2. More than this became unstable.
On my friends pi 1400mhz,SDRAM freq 500 ,overvolt 6 without problem.
Try a mid valute from these settings
After that, to increase performance set the scaling governor to “ondemand” or “performance”:
echo “ondemand” |sudo tee /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
If set on demand, change the up thresold limit from 95 to 60:
echo 60 > /sys/devices/system/cpu/cpufreq/ondemand/up_threshold
With this the CPU freq go up when the CPU load is more of 60%.
This can greatly improve the performance of the pi
It’s a good idea to use a heatsink because the temp go up much more than the older pi
This is very cool!!
The Good news is it does build Nethserver packages
Bad new is I can’t get them installed
Transaction check error:
file /usr/sbin from install of nethserver-release-7arm-0.1.24.ge946f89.ns7.noarch conflicts with file from package filesystem-3.2-18.el7.armv7hl
Did not change much just two typo’s messages.
EDIT 2: fixed this fault in spec file and installed successful
Trying to build a new nethserver-mock for arm threw up this:
DEBUG util.py:468: Executing command: ['btrfs', 'subv', 'list', '/var/lib/mock'] with env {'LANG': 'C', 'TERM': 'vt100', 'SHELL': '/bin/sh', 'HOSTNAME': 'mock', 'HOME': '/builddir', 'PATH': '/usr/bin:/bin:/usr/sbin:/sbin'} and shell Fa$
DEBUG util.py:393: ERROR: can't perform the search - Inappropriate ioctl for device
Any clues? (I saw mock message selinux enabled could that be a clue???)
The package contains the /usr/sbin
directory inside the %file
section, you should remove it.
Please paste the spec file
Odd, i have used this spec file from the beginning…
%define distroversion 7.2.1511
%define distrorelease alpha2
Summary: NethServer YUM repo configuration
Version: 7arm
Release: 0.1%{?dist}
License: GPL
BuildArch: noarch
Source: %{name}-%{version}.tar.gz
URL: %{url_prefix}/%{name}
BuildRequires: nethserver-devtools
%description
NethServer YUM repository configuration
%prep
%setup
%build
perl createlinks
echo %{distroversion} > root/etc/yum/vars/distroversion
echo %{distroversion} > root/etc/e-smith/db/configuration/force/sysconfig/Version
echo %{distrorelease} > root/etc/e-smith/db/configuration/force/sysconfig/Release
echo "NethServer release %{distroversion} (%{distrorelease})" > root/etc/%{name}
%{__install} -d root/%{_nseventsdir}/%{name}-update
%install
rm -rf %{buildroot}
(cd root ; find . -depth -not -name '*.orig' -print | cpio -dump %{buildroot})
%{genfilelist} %{buildroot} > %{name}-%{version}-%{release}-filelist
%files -f %{name}-%{version}-%{release}-filelist
%defattr(-,root,root)
%doc COPYING
%config(noreplace) /etc/yum.repos.d/NethServer.repo
%dir %{_nseventsdir}/%{name}-update
%changelog
Are you using nethserver-mock and nethserver-devtools from @dz00te repo with my mock.cfg file?
I think you don’t need to rebuild nethserver-mock, it’s noarch.
yes
just did this for test exercise (added your mock.cfg)
The nethserver-devtools
provides the genfilelist
script and the one from ns6 branch wants to own any directory, like /usr/sbin
. On ns7 I’ve fixed its behaviour. Could you check the nethserver-devtools
version that is downloaded during mock builds?
Mine is nethserver-devtools-1.1.4-1.5.ga337344.ns7.noarch
here to;
Package Arch Version Repository SizeInstalling:
nethserver-devtools noarch 1.1.4-1.5.ga337344.ns7 nethserver-base 21 k
Installing for dependencies:
freetype armv7hl 2.4.11-11.el7 base 345 k
jbigkit-libs armv7hl 2.0-11.el7 base 44 k
libjpeg-turbo armv7hl 1.2.90-5.el7 base 115 k
libtiff armv7hl 4.0.3-14.el7 base 156 k
libwebp armv7hl 0.3.0-3.el7 base 150 k
python-docutils noarch 0.11-0.2.20130715svn7687.el7 base 1.5 M
python-pillow armv7hl 2.0.0-19.gitd1c6db8.el7 base 419 k
Transaction Summary
Install 1 Package (+7 Dependent packages)
Total size: 2.7 M
Installed size: 9.1 M
No build failures in the logs, cleaning up the chroot has an error (tail root.log)
DEBUG util.py:393: ERROR: can't get rootid for '/var/lib/mock'
DEBUG util.py:515: Child return code was: 1
(logs and faulty package : https://drive.google.com/file/d/0B4zCoP0frJBBMmYxa3VFWmp6aDg/view?usp=sharing)
rather puzzling… I must try to reproduce it!
