Thank, already developed, I saw this code the last weekend, It works
OK for NFS, ro for the whole lan if needed
I called this the lazzy mode, but each IP mus be allowed in the textbox
Similar as above, already coded. I tested nethserver-nfs, either with samba AD or with Openldap, it works on the two scenarios.
we can share the same db property and get for each tab a textarea box to allow the client IP…is it acceptable ?
Or a new separate tab and let the client there…but I don’t like the idea to not get the textbox in the same panel than the NFS one…a bit like you when you want a textbox in the ‘General’ tab
This future is soon, except some code polish and tests, the module is quite good, we can have a look to this now.
