Nethserver-network-diag
great work (as always) tnx @stephdl
it works great also on arm :grin:
after doing a manual update of the MAC vendors about 200 MAC address were correctly identified…
if someone is interested to update the vendor data:
# cd /usr/share/arp-scan
# get-oui -v
# get-iab -v
I thought this night to scan also blue and orange network. Currently it is only green. Do i’m right ?
It could be useful for blue network, but probably you don’t need on orange, since the admin must already know which host are there.
We can put a cron to update it monthly
It seems fair to me. And I wouldn’t mix configuration and diagnostics, probably an email check would be better placed into the email module? I’m in two mind on this
Follow your own rule :smile:
i have had the same doubt with arpwatch… and in my note i write to implement a crontab to do a monthly update of IEEE OUI data :slight_smile:
so yes i think it could be a good choice
Then we should put something like this in the /etc/cron.hourly
#!/usr/bin/bash
cd /usr/share/arp-scan/
get-oui
get-iab
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-diagtools-0.0.1/nethserver-diagtools-0.0.7-1.ns7.sdl.noarch.rpm
with this version you can scan each green/blue interfaces with arp-scan, the vendors are updated each month
nethserver-diagtools RPM is now available from nethserver-testing, as a NethServer core component!
Code: https://github.com/NethServer/nethserver-diagtools
RPM: nethserver-diagtools-0.0.8-1.ns7.noarch.rpm
Thank you @stephdl! :clap: :clap: :clap:
diagtools 007, cool! :sunglasses:
Works like a charme!! Thank you man. You deserve a gold- :medal: . :clap: :clap: :clap:
:heart: core???
Right here and right now!
It seems so…core feature
People are needed there https://github.com/NethServer/dev/issues/5230 You should go and see what is needed to verify the bug…I cannot do it myself I’m the author.
@davidep tested it out by himself. Again, great achievement Steph!
The nethserver-diagtools package is now available from nethserver-updates repository!
It will be shipped as a default package, starting from the next ISO release. To install it on 7.3.1611 run
yum update @nethserver-iso
Otherwise run
yum localinstall http://packages.nethserver.org/nethserver/7.3.1611/updates/x86_64/Packages/nethserver-diagtools-1.0.0-1.ns7.noarch.rpm
Excellent!!! Although I can look at the console, but sometimes it’s not very convenient.:heart_eyes:
@ssabbath Did you see this? :point_up_2:
WOW! As a default package!!! :open_mouth:
Really really good!
please, add speedtest-cli
Command line interface for testing internet bandwidth using speedtest.net
https://github.com/sivel/speedtest-cli
