Does any fail2ban users here have a hostname of vanharen-002.nxs.nl for the internet connection?
Done, the work is a bit more than just rebuild it on NS7.
The main issue I have is that the event nethserver-fail2ban-update is not called by the yum event at the end of the installationâŠthere are no errors in the log message
does something has changed @dev_team ?
https://github.com/stephdl/nethserver-fail2ban/blob/ns7/createlinks
Yes, the new RPM version changed the directory ownership management. Have a look at
http://wiki.nethserver.org/doku.php?id=developer:nethserver_7_kickstart#common_issues
Thank you so much, you saved my day
I just installed and configured without issues F2B for NS7 from @stephdl repository!
The stephdl repository is opened
Thank you Stephane!
@stephdl Iâd like to move this great rpm on NethForge! So you can earn some money for your work and the community has a great new module in his pocket!
any idea on when that is to be released? (F2B itself, I donât use nextcloud)
Is that an âofficialâ NS-repo? Will it be released in the default repoâs, or will it stay in this repo only?
For now, will be stay here.
You can use it safety!
Sir! Youâve made my day. I was looking for Fail2Ban on NS7 and then Iâve luckily found your topic. I can assure you Iâll be using NS7 from today on a small office network as gatewas to the internet, so DHCP, Firewall and OFC Fail2Ban. May I ask what information you require to be shared for furhter developement?
BTW: One small observation for the webconfig. When I click the jails to see what options do they have, I canât close the dropdown menu. Maybe you should use a simple dropdown menu for each jail type?
Bert
@stephdl, I observed the same but workarounded it wrapping each jail in an element list, IIRC. Not sure it was the right way.
It looks good on desktop but IIRC not so on mobile due to the groups columns.
Also, as others noted, the email messages were a bit annoying.
Overall a great work!
Can you share the code you modified ?
Will look for it when I get home this night.
Yep you speak for all the fail2ban starting jails ?
Excerpt: wrapping a jail group within an elementList()
->insert( $view->fieldset(NULL, $view::FIELDSET_EXPANDABLE)->setAttribute('template', $T('NginxStatus_label'))
->insert( $view->elementList()
->insert($view->checkBox('NginxHttpAuth_status', 'true')->setAttribute('uncheckedValue', 'false'))
->insert($view->checkBox('NginxBotSearch_status', 'true')->setAttribute('uncheckedValue', 'false'))
On December I did some other noobie tests, mangling some elements⊠but didnât go anywhereâŠ
Test 1:
Test 2:
Exactly.
at the time it was not possible to filter (by fail2ban) what mails to send :â(
Maybe it could be searched now
what do you think to add your modifications with another Tab. It will add more spaces !
