NethServer 7 RC2 crashes when I install / uninstall module or update system
less /etc/sysconfig/kernel
# at https://dev.nethesis.it/projects/nethserver/wiki/NethServer
# original work from http://www.contribs.org/development/
# Copyright (C) 2013 Nethesis S.r.l.
# http://www.nethesis.it - support@nethesis.it
# UPDATEDEFAULT specifies if new-kernel-pkg should make
# new kernels the default
UPDATEDEFAULT=yes
# DEFAULTKERNEL specifies the default kernel package type
DEFAULTKERNEL=kernel
EOF
I successfully changed the /etc/sysconfig/kernel?
if you give me an ok, I proceed with yum reinstall grubby -y
That line must be removed
I followed your directions, backed reinstall the grubby.
Now how can I check if the upgrade was successful, and the installed modules are working properly?
Although the process of installation is not completed in a linear way, I still have to perform signal-event nethserver-sssd-save?
Doing it one more time does not harmā€¦ Yes, do it.
Log in on server-manager: if dashboard, user and groups show correctly Iā€™d say youā€™re ok.
Check the kernel version in dashboard is 3 (no more lt).
Test also login on roundcubemail.
I launched the command signal-event nethserver-sssd-save, but no signs of life.
Again finding of saturation problems of RAM and SWAP. In the dashboard screen is visible memory saturation and the kernel version
Open a shell and type
chmod -x /etc/e-smith/events/actions/nethserver-directory-sssd
Letā€™s see if it stabilizes before starting to kill processesā€¦
BTW your kernel is still LT! You must boot with the upstream kernel.
ok! RAM was almost completely free, idem for swap.
I also relaunched signal-event nethserver sssd-save and this time it was successful.
Now itā€™s hard for me to reboot remotely and select the right kernel.
I do not know ways to do it.
The grubby command you issued above should select it automatically but it seems it didnā€™t work!
which kernel is the right one?
   # grep '^menuentry' /boot/grub2/grub.cfg
    menuentry 'CentOS Linux (4.4.22-1.el7.elrepo.x86_64) 7 (Core)' --class centos --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-3.10.0-327.el7.x86_64-advanced-a260fbcd-cb7b-4a08-8c24-0c300d78e506' {
    menuentry 'CentOS Linux (3.10.0-514.2.2.el7.x86_64) 7 (Core)' --class centos --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-3.10.0-327.el7.x86_64-advanced-a260fbcd-cb7b-4a08-8c24-0c300d78e506' {
    menuentry 'CentOS Linux (3.10.0-327.el7.x86_64) 7 (Core)' --class centos --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-3.10.0-327.el7.x86_64-advanced-a260fbcd-cb7b-4a08-8c24-0c300d78e506' {
    menuentry 'CentOS Linux (0-rescue-87dba42dfea045a9a4bcda15160cfb11) 7 (Core)' --class centos --class gnu-linux --class gnu --class os --unrestricted $menuentry_id_option 'gnulinux-0-rescue-87dba42dfea045a9a4bcda15160cfb11-advanced-a260fbcd-cb7b-4a08-8c24-0c300d78e506' {
Second one:
Since you didnā€™t fix the grubby template before the update, you now need to set the default kernel by hand.
Execute:
grubby --set-default /boot/vmlinuz-3.10.0-514.2.2.el7.x86_64
Then reboot the machine. After the reboot, remove the lt kernel:
yum remove kernel-lt
More info: https://docs.fedoraproject.org/en-US/Fedora/23/html/System_Administrators_Guide/sec-Configuring_GRUB_2_Using_the_grubby_Tool.html
@giacomo thanks! I managed to remove the kernel-lt and set the right kernel
We are testing a package that seems to fix your high load problem: do you want to help us?
Please install it by typing at the command line
yum --enablerepo=nethserver-testing update nethserver-directory
ā€¦ and letā€™s see if the issue comes back!
Sure Iā€™ll help you! I updated the package by following your instructions.
Before I had problems in the management of the account, but now it seems that everything is working again.
I proceed with reinstalling roundcube, letā€™s see if I memory problems again
roundcube works again! thank you so much for your time!
