MailServer Configuration (autodiscover, SPF, DKIM)
thank you very much for your assistance. DKIM, SPF, and DMARC records are up and working.
$ amavisd genrsa /etc/pki/tls/private/example.com-dkim.key.pem
$ chgrp amavis /etc/pki/tls/private/example.com-dkim.key.pem
$ chmod g+r /etc/pki/tls/private/example…com-dkim.key.pem
$ mkdir -p /etc/e-smith/templates-custom/etc/amavisd.conf
$ nano /etc/e-smith/templates-custom/etc/amavisd.conf/95dkim
#filippo enable dkim
$enable_dkim_verification = 1;
$enable_dkim_signing = 1;
$log_level = 5;
dkim_key('example.com', 'dkim', '/etc/pki/tls/private/example.com-dkim.key.pem');
@dkim_signature_options_bysender_maps = ( \{ '.' => \{ ttl => 21*24*3600, c => 'relaxed/simple' \} \} );
$ signal-event nethserver-mail-filter-update
$ signal-event nethserver-mail-server-update
$ amavisd -u amavis -g amavis -c /etc/amavisd.conf showkeys
https://support.google.com/a/answer/2466563?hl=en - used for DMARC
http://www.mailradar.com/spf/ - used for SPF
Great job man! Thanks for your feedback :wink:
@filippo_carletti is it ready to be added to the core? Or needs more tests?
Happy New Year!
Is it possible someone to confirm that recently, dkim signing of outgoing mails is working, as discussed here a year ago?
I didn’t check recently, but I think that DKIM signing works only if you use a disclaimer text.
Hi Fillipo !
Thanks for your feedback - you are absolutely correct, DKIM signing works only when disclaimer text is used.
Sorry to bring on this subject under the carpet again but
I followed the @tzar instruction on a Nethserver 7
and the result is :
$ amavisd -u amavis -g amavis -c /etc/amavisd/amavisd.conf showkeys
No DKIM private keys declared in a config file.
####and
cat /etc/amavisd/amavisd.conf |grep dkim
$enable_dkim_verification = 0; # disable DKIM signatures verification
$enable_dkim_signing = 0; # disable DKIM signing code
###So I double check and obviously can’t see my mistake
####95dkim config file
cat /etc/e-smith/templates-custom/etc/amavisd.conf/95dkim
# filippo enable dkim
$log_level = 5;
dkim_key(‘domain1.tld’, ‘dkim’, ‘/etc/pki/tls/private/domain1.tld-dkim.key.pem’);
@dkim_signature_options_bysender_maps = ( { ‘.’ => { ttl => 21243600, c => ‘relaxed/simple’ } } );
$log_level = 5;
dkim_key(‘domain2.tld’, ‘dkim’, ‘/etc/pki/tls/private/domain2.tld-dkim.key.pem’);
#####REMARK:
  • the @dkim_signature_options_bysender_maps = is in one line
  • the file is group owned by amavis and this group have the right to read
I think you have to give the command
instead of
Thank paolo;
but the file amavisd.conf is, in my case at least, really in /etc/amavisd/amavisd.conf
Any luck with DKIM for Nethserver 7?
I’ve followed these instructions successfully on NS7. The configuration file is now /etc/amavisd/amavisd.conf and so you’ll need to edit /etc/e-smith/templates-custom/etc/amavisd/amavisd.conf/95dkim (for example) rather than /etc/e-smith/templates-custom/etc/amavisd.conf/95dkim.
It works!!! Happy signing…
$ mkdir -p /etc/e-smith/templates-custom/etc/amavisd/amavisd.conf
$ nano /etc/e-smith/templates-custom/etc/amavisd/amavisd.conf/95dkim
$log_level = 5;
Add the disclaimer by going to the server control panel, on the left hand side, Configuration -> Email. Press edit beside your domain name and add your disclaimer.
I know this is an old thread, but for the sake of anyone finding it in a search, this setting won’t (by itself) do anything to make email clients automatically discover your server settings. Information on a simple configuration for this purpose is in this thread, and hopefully an automx module will be available soon which will handle all this stuff.
Hi @danb35
I tried to edit it to remove this part but I think because @alefattorini edit it after me I lost the edtion right on it .
my sending score is exceptional. thanks to the dkim signing in nethserver and other spf configurations
This old topic was about DKIM with amavisd…
I guess you got that score with the new mail module of NethServer 7.5, right?
yes that was the case
