NethServer Version: 7.3.1611 (Final) + last update
Module: firewall
i use only green interface.
I use DHCP and IP reservation it’s work fine!
if i set checkbox MAC validation (IP/MAC binding) in Firewall it’s see me error
sorry my English…
Module: firewall
sorry my English…
MAC validation has been designed only for firewalls, thus you need a green and a red interface.
If you want to modify the behavior, you could create a template-custom for this fragment: /etc/e-smith/templates/etc/shorewall/interfaces/20nics
I do not know how…
You can find all information about template custom here:
http://docs.nethserver.org/projects/nethserver-devel/en/v7/templates.html#local-site-overrides-templates-custom-and-templates-user-custom
WARNING: It’s only a idea: I don’t know if it works or not
Create a template custom:
mkdir -p /etc/e-smith/templates-custom/etc/shorewall/interfaces
cd /etc/e-smith/templates-custom/etc/shorewall/interfaces
cp /etc/e-smith/templates/etc/shorewall/interfaces/20nics .
Modify 20nics under /etc/e-smith/templates-custom/etc/shorewall/interfaces
vi 20nics
Row 21:
$OUT .= "net\t".$i->key."\tdhcp,nosmurfs,optional";
to
$OUT .= "net\t".$i->key."\tdhcp,nosmurfs,optional".$mac_option;
save the file, then:
expand-template /etc/shorewall/interfaces
signal-event firewall-adjust
Put the check again on the option where you have error (I don’t find that option in my dashboard…) then make a test.
If this doesn’t work reverse the modify:
rm 20nics
