NethServer Version: v7 Module: Chat
I have users created in nethserver. Each user belongs to a group also created in nethserver. In my client program Jabber( I use Spark) I see all the users together and not in groups. I don´t see the groups I have created.
The only groups I see are : Unclasified users and disconnected users.
Hello @davidep
I am migrating a Zentyal to Nethserver, I have about 100 employees divided by departments and places. Currently in Zentyal 3 I have it created and is very comfortable, see image:
We removed the support for groups on NS 7 because there is no a convenient way to have the feature both for AD and LDAP. Maybe we can try to fix it in the future.
It seems we forgot to update the documentation for NS 7, thanks for pointing out.
You can create a template custom to fix it for LDAP, take a look at this commit (you need the left part):
Hi @giacomo
we modified all the files and left them as you have on the left part of your commit unless the first one, nethserver-ejabberd.spec, because we couldn´t find it. We can´t still see our groups. And now the service starts but we can not connect.
I have tried, but I do not get it to work, my knowledge is insufficient.
I hope in future updates it works.
By curiosity provides in Nethserver 6.9 and if the groups leave but leave as if they were users, not as groups containing users, so it also did not work correctly.
I think this is an important issue since if you have many users it is difficult to locate them in a list and more when many employees do not know each other or are called similar.
