Hi @davidep,
I have tried to install WebTop 5 on a new Ns7.3 Final and I have this error:
Failed:
tomcat.noarch 0:7.0.69-10.el7
Hi @davidep,
Failed:
I can reproduce it and, probably, I’ve fixed it with an updated webtop5-libs package.
Sadly there is no easy way to recover the broken installation, you should try to reinstall on a clean machine.
Thank you!
No, problem!
I will reinstall from scratch, tomorrow.
I had no error with installing WT5 on a new installed NS7 from iso with all updates.
Seems you have fixed the issue with the new webtop5-libs package.
Installed without issues!
Thank you again!
PS:
Can you mark this topic as “Solved”, please?
I only can edit the title like this:
[SOLVED] Issues installing WebTop 5
Good idea!
For now should work
What about changing the category from “webtop” to “support”? Then it should be possible to markit as solved.
@alefattorini split this topic from another and I think only him can mark this topic as solved because Alessio became “the owner”.
I think the category is good.
In this category we can put all topics regarding WebTop.
That’s the aim, I just add the “mark solved” feature to the webtop category.
We see how it goes and if new subcategories are needed.
