Import of users on NS 7 RC3
NS7 RC3
We are trying to import a SME 8 backup to NS (only file share and LDAP) and got the following errors
Dec 19 19:24:02 nsrv esmith::event[2258]: [ERROR] user-create event failed for user username
Dec 19 19:24:02 nsrv esmith::event[2258]: [ERROR]: user domains is missing in passwd DB! User creation failed?
Dec 19 19:24:02 nsrv esmith::event[2258]: [ERROR]: user username is missing in passwd DB! User creation failed?
Dec 19 19:24:03 nsrv esmith::event[2258]: [ERROR] user-create event failed for user username
Dec 19 19:24:03 nsrv esmith::event[2258]: [ERROR]: user username is missing in passwd DB! User creation failed?
Dec 19 19:24:04 nsrv esmith::event[2258]: [ERROR] user-create event failed for user username
Dec 19 19:24:04 nsrv esmith::event[2258]: [ERROR]: user username is missing in passwd DB! User creation failed?
Dec 19 19:24:04 nsrv esmith::event[2258]: [ERROR] user-create event failed for user specials
Dec 19 19:24:05 nsrv esmith::event[2258]: [ERROR] user-create event failed for user username
Dec 19 19:24:05 nsrv esmith::event[2258]: [ERROR]: user username is missing in passwd DB! User creation failed?
The db accounts does have the users but the server-manager page does not display anything other than admin. But the groups are listed. I can add a user to a group even though they are not displaying. No home directories have been created nor data migration. Ibays are fine.
It was a clean install into a VM. Should we have created the users manually before import?
Thanks
Hi Gordon,
migration from SME 8 is not ready yet :slight_smile:
We are working on it, please be patient!
Hi Giacomo
This was on a test Vm machine. So if there is anything you would like us to
test please ask/advise.
When 7 is release will 6.8 migrate up or will it need format and reload?
Regards
Gordon
Thank you for your help! We’re working on the migration procedure. It is developed separately from the Final release.
We will make an attempt with the upstream upgrade tool. I hope it works :wink:
For more info
BTW, some users&groups import scripts from CSV already exist
