How to Block zenmate-vpn & NetCut
NethServer Version: 6.9
Module: firewall
I am using NS 6.9 Version running successful with DHCP,WebProxy,WebContentfilter & Firewall. But our end users by-passing proxy using ‘zenmate VPN’ software & using ‘NetCut’ software they are disconnecting other users from the LAN.
Could you please help.
I guess your users are connected to wifi. You have to enable client isolation in your AP to disable netcut.
You can find instructions to block zenmate on the net.
Good to hear…Let me check
