So i figured out that setting up the ipsec tunnel correctly wasn´t the solution. After 4 Days my RAM Usage is that high again:
Any further ideas?
Any further ideas?
Anything relevant from:
journalctl -u ipsec.service
Very many entries like this:
"Site-to-Site"[1] 79.235.11.89 #11118: Aggressive mode peer ID is ID_FQDN: '@cloud.myipsecpartner.de'
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11118: EXPECTATION FAILED at /builddir/build/BUILD/libreswan-3.15/programs/pluto/ikev1.c:2843: r != NULL
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11118: no suitable connection for peer '@cloud.myipsecpartner.de'
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11118: initial Aggressive Mode packet claiming to be from @myipsecpartner.no-ip.org on 79.235.11.89 but no connection has been authorized
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11118: sending notification INVALID_ID_INFORMATION to 79.235.11.89:500
Jul 19 13:05:45 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: received Vendor ID payload [XAUTH]
Jul 19 13:05:45 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: received Vendor ID payload [Dead Peer Detection]
Jul 19 13:05:45 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: received Vendor ID payload [RFC 3947]
Jul 19 13:05:45 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: ignoring Vendor ID payload [draft-ietf-ipsec-nat-t-ike-03]
Jul 19 13:05:45 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: ignoring unknown Vendor ID payload [a2226fc364500f5634ff77db3b74f41b]
Jul 19 13:05:45 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: IKEv1 Aggressive Mode with PSK is vulnerable to dictionary attacks and is cracked on large scale by TLA's
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11119: Aggressive mode peer ID is ID_FQDN: '@cloud.myipsecpartner.de'
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11119: EXPECTATION FAILED at /builddir/build/BUILD/libreswan-3.15/programs/pluto/ikev1.c:2843: r != NULL
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11119: no suitable connection for peer '@cloud.myipsecpartner.de'
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11119: initial Aggressive Mode packet claiming to be from @myipsecpartner.no-ip.org on 79.235.11.89 but no connection has been authorized
Jul 19 13:05:45 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11119: sending notification INVALID_ID_INFORMATION to 79.235.11.89:500
Jul 19 13:05:46 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: received Vendor ID payload [XAUTH]
Jul 19 13:05:46 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: received Vendor ID payload [Dead Peer Detection]
Jul 19 13:05:46 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: received Vendor ID payload [RFC 3947]
Jul 19 13:05:46 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: ignoring Vendor ID payload [draft-ietf-ipsec-nat-t-ike-03]
Jul 19 13:05:46 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: ignoring unknown Vendor ID payload [a2226fc364500f5634ff77db3b74f41b]
Jul 19 13:05:46 net01.myserver.co pluto[1866]: packet from 79.235.11.89:500: IKEv1 Aggressive Mode with PSK is vulnerable to dictionary attacks and is cracked on large scale by TLA's
Jul 19 13:05:46 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11120: Aggressive mode peer ID is ID_FQDN: '@cloud.myipsecpartner.de'
Jul 19 13:05:46 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11120: EXPECTATION FAILED at /builddir/build/BUILD/libreswan-3.15/programs/pluto/ikev1.c:2843: r != NULL
Jul 19 13:05:46 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11120: no suitable connection for peer '@cloud.myipsecpartner.de'
Jul 19 13:05:46 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11120: initial Aggressive Mode packet claiming to be from @myipsecpartner.no-ip.org on 79.235.11.89 but no connection has been authorized
Jul 19 13:05:46 net01.myserver.co pluto[1866]: "Site-to-Site"[1] 79.235.11.89 #11120: sending notification INVALID_ID_INFORMATION to 79.235.11.89:500
I´m wondering about these entries because “myipsecpartner.no-ip.org” is an old domain and does not appear in any configuration file.
Can you tell me which configurationfile openswan uses? /etc/ipsec.conf or /ipsec/ipsec.d/tunnels.conf
it’s normal and a good thing… you have to worry only if you’ll see your swap usage increase…
Linux is very efficient and it uses all the available ram…
in nethserver libreswan is using /etc/ipsec.d/tunnels.conf
(handled through e-smith templates)
So the conf file /etc/ipsec.conf and ipsec.secrets are not necessary? Deleting the files and restarting ipsec (service ipsec restart) gives:
[root@net01 ~]# systemctl status ipsec.service
● ipsec.service - Internet Key Exchange (IKE) Protocol Daemon for IPsec
Loaded: loaded (/usr/lib/systemd/system/ipsec.service; enabled; vendor preset: disabled)
Active: failed (Result: start-limit) since Sun 2017-07-23 15:52:10 CEST; 40s ago
Process: 1407 ExecStopPost=/usr/sbin/ipsec --stopnflog (code=exited, status=0/SUCCESS)
Process: 1404 ExecStopPost=/sbin/ip xfrm state flush (code=exited, status=0/SUCCESS)
Process: 1401 ExecStopPost=/sbin/ip xfrm policy flush (code=exited, status=0/SUCCESS)
Process: 1389 ExecStop=/usr/libexec/ipsec/whack --shutdown (code=exited, status=0/SUCCESS)
Process: 1423 ExecStartPre=/usr/libexec/ipsec/addconn --config /etc/ipsec.conf --checkconfig (code=exited, status=3)
Main PID: 5006 (code=exited, status=0/SUCCESS)
Jul 23 15:52:10 net01.myserver.co systemd[1]: ipsec.service: control process exited, code=exited status=3
Jul 23 15:52:10 net01.myserver.co systemd[1]: Failed to start Internet Key Exchange (IKE) Protocol Daemon for IPsec.
Jul 23 15:52:10 net01.myserver.co systemd[1]: Unit ipsec.service entered failed state.
Jul 23 15:52:10 net01.myserver.co systemd[1]: ipsec.service failed.
Jul 23 15:52:10 net01.myserver.co systemd[1]: ipsec.service holdoff time over, scheduling restart.
Jul 23 15:52:10 net01.myserver.co systemd[1]: start request repeated too quickly for ipsec.service
It’s necessary but NethServer stores the config under /etc/ipsec.d/, leaving the default conf file untouched
(NethServer settings are stored in the vpn database)
Ah okay. Does anybody know how to delete the old domain from nethserver vpn database?
Do you see the old settings here?
db vpn show # (don't share the psk)
yes i can see the old settings
If it doesn’t show up on the UI, you can delete it with:
db vpn delete yourtunnelname
signal-event nethserver-ipsec-tunnels-update
Make sure to choose the tunnel you want to delete.
If you don’t want to delete the tunnel but a specific property, the manual and the wiki have more information about the databases.
Okay i was wrong. I can´t see the old setting with “db vpn show”… I was confused by a command before… Is there any other possible reason why it shows the old config in “journalctl -u ipsec.service” ?
I think back to basics here. Find out what is using the swap space and not just try and guess. Here is a very simple script:
for file in /proc/*/status ; do awk '/VmSwap|Name/{printf $2 " " $3}END{ print ""}' $file; done | sort -k 2 -n -r
Or this question on Stackoverflow has a few scripts to try.
Or another page with various methods to investigate swap space.
Cheers.
Thank you! I´ll try this script when my swap RAM is getting in usage again.
I realized that my Swap RAM gets higher and i runned your script. It shows this:
[root@net01 ~]# for file in /proc/*/status ; do awk '/VmSwap|Name/{printf $2 " " $3}END{ print ""}' $file; done | sort -k 2 -n -r
xfs-reclaim/sda
xfs-reclaim/dm-
xfs_mru_cache
xfs-log/sda1
xfs-log/dm-0
xfs-eofblocks/s
xfs-eofblocks/d
xfs-data/sda1
xfs-data/dm-0
xfs-conv/sda1
xfs-conv/dm-0
xfs-cil/sda1
xfs-cil/dm-0
xfs-buf/sda1
xfs-buf/dm-0
xfsalloc
xfsaild/sda1
xfsaild/dm-0
writeback
watchdog/3
watchdog/2
watchdog/1
watchdog/0
vballoon
tuned 0 kB
ttm_swap
tlsmgr 0 kB
systemd-udevd 0 kB
systemd-logind 0 kB
systemd-journal 0 kB
systemd 0 kB
sshd 0 kB
sshd 0 kB
sort 0 kB
smwingsd 0 kB
smartd 0 kB
scsi_tmf_1
scsi_tmf_0
scsi_eh_1
scsi_eh_0
rsyslogd 0 kB
rpciod
rcu_sched
rcu_bh
qmgr 0 kB
pppoe-connect 0 kB
pppd 0 kB
polkitd 0 kB
_pluto_adns 0 kB
pluto 0 kB
pickup 0 kB
openvpn 0 kB
netns
migration/3
migration/2
migration/1
migration/0
md
master 0 kB
lvmetad 0 kB
kworker/u8:1
kworker/u8:0
kworker/3:2H
kworker/3:2
kworker/3:1H
kworker/3:1
kworker/2:2
kworker/2:1H
kworker/2:1
kworker/2:0H
kworker/2:0
kworker/1:3
kworker/1:1H
kworker/1:1
kworker/1:0H
kworker/1:0
kworker/0:1H
kworker/0:1
kworker/0:0H
kworker/0:0
kthrotld
kthreadd
kswapd0
ksoftirqd/3
ksoftirqd/2
ksoftirqd/1
ksoftirqd/0
ksmd
kpsmoused
kmpath_rdacd
kintegrityd
khungtaskd
khugepaged
kdmflush
kdmflush
kdevtmpfs
kblockd
kauditd
irqbalance 0 kB
ipv6_addrconf
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
httpd 0 kB
gssproxy 0 kB
fsnotify_mark
fail2ban-server 0 kB
dnsmasq 0 kB
deferwq
dbus-daemon 0 kB
crypto
crond 0 kB
cifsiod
chronyd 0 kB
bioset
bioset
bioset
bash 0 kB
bash 0 kB
bandwidthd 0 kB
bandwidthd
awk 0 kB
auditd 0 kB
ata_sff
agetty 0 kB
addconn
My RAM at the moment:
Your server is fine
It isn’t using any swap, it’s a good thing
Don’t worry
