Guide to the use of dpi libraries
Hello everybody saw that in nethserver have been integrated the dpi libraries I wanted to know if there is a guide to the use of the same
thank you
Here you are:
http://docs.nethserver.org/en/v7/firewall.html#deep-packet-inspection-dpi
It’s not much, but if you tell us exactly what you’re looking for, we can improve the documentation.
And you would be really comfortable creating a guide to use
I totally agree… a didactic documention is lacking.
On a forum I found some help for
Iptables -minds --help you get the basic commands for running them
Example: iptables -mndpi --prote facebook, twitter, instagram, windows_update
In the example, facebook, twitter, instagram and windows_update are blocked
iptables -mndpi --help
is correct
sorry
We can add more documentation, but I need to know what you’re expecting to see on it :slight_smile:
You shouldn’t need any technical documentation to use is, since you can do everything from Firewall Rules page.
By the way, you can find more info here:
GitHub - NethServer/xt_ndpi-kmod (see also links on the README).
@m_farlotta did you find enough information?
If you have doubts, please ask here and I will try to answer to any question.
This should be a good starting point for improving the doc.
That’s a good way to address the request. Documentation should answer some questions. What are the questions?
